Deleted member 19315
I recently replaced my incorrect headlamp trims with the correct deeper ones with a rivet in the top. . They look much better but I still have the ugly edge of the headlamp bowl gasket showing around its edge . My questions are:-
are the gaskets on an aftermarket plastic headlamp bowl bigger in diameter than originals?
can I get smaller ones ?
should I use the rubber dust shields that are available to go inside the trims?
shall I change back to the metal two piece bowls?
PS. I have Wipac Quadoptic H4 headlamps.
Andy
Andy
