I would think that just connecting a VOM meter to check its resistance as you move it slowly through its range would do it. Visually it looks pretty good. I think that the major problems with them is the lever not making contact or the resistance coil having a break in it. May also have some continuity issues at the terminal end's.
I always connect a ground wire from the case to one of the bolts holding the gas tank. This assures a good ground.
Scott in CA.
Looks like an original unit.....some of the aftermarket ones are junk!
The aftermarket units have a very coarsely wound coil.
