Fuel Sending Unit Float
BJones
Does anyone know if I can purchase and install only the float on my 71 TR6 fuel sending unit? My fuel gauge reads "E", and if I use a metal coat hanger to lift the float inside the gas tank the gauge will move. I am guessing that the float has a crack or a hole in it. The PO told me it used to work just after the rebuild, then shortly there after it started to slowly sink. We both guessed the float had a small crack he did not notice when putting it back together. I would like to avoid spending $50 on a new Unit from Moss if I can. I would also like to avoid having to take the car apart twice if I can. Any help is appreciated.
Thanks,
Brent
martx-5
Just remove the float that's on there, and stuff a cork on the end of the arm. /ubbthreads/images/graemlins/jester.gif
Seriously, if the float's cracked, you should be able to empty it out and epoxy it shut. The big problem is, can you get the sending unit out without removing the tank?
B
BJones
For what it is worth, the PO says I just have to remove the panel in the trunk and there are 2 bolts that hold the top of tank in place. After I remove those 2 bolts the tank should rock back and I can easily remove the entire sending unit. The cork is a good idea. I will probably try to do the epoxy first. I thought about that, but thought the fuel might eat away the epoxy and I would be in the same situation. I guess I just have to find the right type of epoxy... (duh) Thanks for the help.
Adrio
Don't use any old epoxy. I would go get some of the gas tank repair epoxy from the auto parts places. It comes as a putty almost and you mix the two parts together like epoxy. I have used that stuff to repair tank leaks (not in a Triumph), as a stop gap measure, while gas was flowing out the crack. It worked fine and from what I hear is still holding up 6 years later.
G
[ QUOTE ]
[/ QUOTE ]
There is a little more to it than that. First off, the tank is held in place by four bolts, 2 top and 2 bottom. Not only that but there is the little matter of the filler hose which will have to be removed, including the filler cap. Then you have the bottom of the tank that has a rigid hose exiting down through a hole in the body to a short flexible rubber hose and on to the rest of the rigid fuel line. None of this stuff is going to allow you to "just tip the tank" without ripping something apart. Removing the whole tank is not that tough, just make sure it is almost completely drained first. Either use up most of the fuel and/or undo the flexible rubber hose and drain safely into a gas can. There really is no long term way to repair the float. The original float will be so old that it isn't worth repairing and the aftermarket floats aren't available without the whole unit. Pull the tank and just put in a new sending unit. Not really that expensive.
Bill
dklawson
I haven't seen a TR6 float before so I don't now if the following could be made to work, but....
On the Healey forum of this board a crossreference was posted that used a Ford float. Sorry if this link is too long to work. If it fails, use the search feature set back to one year using the keyword "float". This thread ran in July in the Healey forum.
https://www.britishcarforum.com/ubbthread...true#Post230300
Regarding epoxy, though I hate to say it, you can use JB Weld. Really. I wouldn't have tried or believed this myself, but I was advised to use JB Weld to modify a late model Solex float for use in a an early VW carb. The source was an engine builder who I trust. It worked... just like he said it would.
B
BJones
Awe shucks, I guess I will have to go for a long drive to burn off some of the fuel... I will keep you all posted. I will let you know what I decide to do. I might have to get in there and see how bad the float looks. Thanks for all the help.
Brent
B
BJones
I know it has been a while since this was discussed, but I thought I would pass on my findings. My float was cracked and sunk. I took it out and headed over to Motorhead while on my lunch break. They had a used replacement for only $5. The guy behind the counter also told me it is the exact same one they have for MG's. The only difference is you can buy just the float for the MG from Moss for $14.95, they don't sell the TR6 float by itself. He pulled two new fuel sending units off the shelf to compare (one TR6 one MG) and the floats were identical. I also bought a new cork seal for $2. I will hopefully have a working Fuel guage this weekend. /ubbthreads/images/graemlins/thumbsup.gif
G
Hey Brent,
Thanks for doing all that research for the rest of the forumites. Little things like that save the rest of us bucks and aggravation. Keep it up.
Bill
B
BJones
Glad to help. I have already gained an immeasurable amount of help and info from everyone here. I just figured I would try and do my part.
dklawson
They don't sell replacement floats for Minis either. Could you measure the float you bought (or the cracked one) and tell me the OD, length, and the diameter of the gland where it clips onto the float arm? Thanks.
B
BJones
Doug, Sorry I didnt see this sooner, I just looked back up the post as I did the exchange on the float last night. Here are the dimensions and a picture that will hopefully help you. L= 2 1/8" OD= 4" and the OD where the float attaches to the gland is just a hair smaller than 4". It kind of looks similar to the head of a coat hanger. It just clips into place on the left end of the float in the picture. I think if you look at the picture it will all make sense. Let me know if you need any further help. /ubbthreads/images/graemlins/cheers.gif
martx-5
[ QUOTE ]
... Here are the dimensions and a picture that will hopefully help you. L= 2 1/8" OD= 4" ...
[/ QUOTE ]
Looking at the attachment, if the length is 2 1/8", I can't see how the OD (Outside Diameter) can be 4". Are you sure you don't mean that CIRCUMFERENCE is 4"??
B
BJones
Good catch Art. You are right. The OD is 1 3/16".
dklawson
Thanks Brent. I'm trying to come up with alternate floats for sending units used in cars like my Mini and GT6. This float seems to be a little bit longer than that used on the Mini but basically the same dimensions as that used on a friend's Triumph 2000. It also sounds very close in size to the brass Ford floats posted a while back in the Healey Forum on this board. Perhaps Smiths standardized on a common plastic float size in the mid-1960s. That would be great news as both your float and the Ford one might be replacements for our old sinkers. As you pointed out, these replacements are a lot less expensive than a new sending unit.
Thanks again!
BoyRacer Fuel Tank Sending Unit Austin Healey 3
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
Joe Schlosser Bug Eye fuel gage sending unit Spridgets 15
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
TulsaFred Fuel Sending Unit Spridgets 4
rjc157 fuel tank sending unit Austin Healey 4
R Fuel sending unit Austin Healey 4
V Fuel Gauge Sending Unit Austin Healey 3
C TR2/3/3A fuel sending unit Triumph 9
6 Fuel gauge, sending unit, and tank compatibility Spridgets 9
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
pkmh BJ8 Fuel Tank Sending Unit - Ground Wire Austin Healey 8
R TR2/3/3A TR3A Fuel sending unit Triumph 3
bugedd Fuel tank sending unit Spridgets 18
E BE Fuel Sending Unit Wire Spridgets 0
stretchit2 Fuel Sending Unit - Short? Austin Healey 16
M Tell me I need a fuel tank sending unit Spridgets 21
AUSMHLY fuel sending unit float position Austin Healey 16
bugedd Fuel Sending unit Question Spridgets 6
G Fuel Gauge - Sending Unit Question Austin Healey 20
T TR6 tr6 fuel sending unit Triumph 5
M Smiths Fuel Tank Sending Unit Austin Healey 3
W Wiring to BE fuel tank sending unit Spridgets 4
W Wiring the fuel tak sending unit Spridgets 2
6 fuel sending unit Triumph 3
M Smiths fuel tank sending unit Triumph 1
TimK Erratic Fuel Sending Unit Austin Healey 10
AUSMHLY Who makes the best fuel sending unit Austin Healey 4
AUSMHLY Fuel sending unit Austin Healey 1
boxofparts MGB 79 MGB Fuel Level Sending Unit MG 6
T Fuel sending unit Triumph 34
S TR2/3/3A Tr3 fuel gauge sending unit Triumph 6
G Fuel tank sending unit gasket leaks.....quick fix? Triumph 5
philman fuel sending unit MG 1
C Fuel Level Sending Unit MG 4
philman fuel guage sending unit MG 19
bighly Fuel Sending Unit Leakey Float Replacement Austin Healey 9
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
C TR2/3/3A TR3 Fuel Gauge Sending Unit Triumph 2
H Fuel Tank Sending Unit Float Austin Healey 11
Alan_Myers TR4/4A Fuel tank sending unit - TR4 Triumph 2
kindofblue Front Dust Caps Problem & Seized fuel Sending Unit Triumph 9
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
J Fuel gauge sending unit Austin Healey 2
bighly Fuel level sending unit leak Austin Healey 1
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
