Front hub puller?
drooartz
What sort of hub puller do I need for the front hubs? I'm in the process of disassembling my disc fronts, and need to get them apart so I can send the A-frames/kingpins out for rebuilding.
Drew, No hub puller needed. If you have wire wheel hubs there is a grease cap that can stump you briefly, but otherwise, undo the split pin, undo the nut, and pull. It will come off disturbingly easy.
Peter C.
These are disc wheels. So I can just pull the hub off the stub axle? Geesh...
Not much force at all. One of mine needed very little persuasion with a 3 armed puller, the other one came right off.
I'll give it a go tonight. I'll admit, I never even tried to pull them off, figured the tool was necessary.
Well, that's what the manual said! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Peter C.
Don't forget about the tabbed washer behind the nut. If you don't remove that first, it can make things a little more difficult.
Sure enough, couple good pulls and everything came off. Just need to get the bearings out, and all will be well. A-frames and kingpin are ready to be sent out for work now.
Drew, you rolling right along.
