Jim_Gruber said:
Frank C. did a forward tilting bonnet on PIECES...
I swapped Email with Frank C. yesterday, here's what he had to say:
'PIECES had a normal front opening bonnet but I have done the forward
tilt on a 69 Midget with a bugeye nose last year.
I used the later style scissor hinges as my front mounting tilt
brackets. I just took the hinges apart and used a couple piece of them.
I don't remember exactly how I did it, it was sort of a cut and fit type
of deal.
I mounted the brackets to where the bumper bolts and used a 1/4" rod as
the pivot. 2 hair pins and the rod pulled out for easy bonnet removal.
I used an old signal plug for the lights and horn wiring so I could just
unplug the bonnet wiring from it.
The brackets are not hard to make, they have to point up and out just a bit.
I sold that 69 so I can't even take a look at it.
I attached the only picture of it with the bonnet open, no real help but
you can see the support/stop cables.'
Ray
