Fixing Things
jhorton3
Finally have time this weekend to work on Midgie. Fixed one of the major oil leaks. For some reason the braided oil pressure hose developed a leak on the block side connection. Looked like I'd cut a main artery! With replacement not a drop leaked.
Tomorrow I plan on working to get the static timing back. Not looking forward to it as I'll have to unbolt the motor mounts and jack the engine up so I can get a socket on the damper pulley bolt. I'll probably be posting quite a bit tomorrow asking plenty of questions.
Bugeye58
Whoa!! It's not necessary to jack anything up to turn the engine over by hand.
Pull the plugs, chock the wheels or apply the handbrake, gearbox in neutral.
Apply pessure on the alternator belt, put a wrench on the alternator pulley nut and turn to your hearts content. Much easier. Someone will suggest pushing the car, or rocking it while in gear, but my method is easier, and it's much more precise.
While you're there, it would be the ideal time to adjust the valves, too.
Jeff
asoupley
That's a good tip Jeff... I usually do the "push the car method". Maybe I'll try this one next time
Thanks
Tony
Baz
I've been jacking up one rear wheel in 4th and turning the wheel. Your suggestion sounds a lot easier Jeff.
jhorton3
jhorton3
Plugs have been pulled, I've tried getting the alternator belt as tight as I can possibly muster, but the alternator pulley method will not turn the engine at all. Just slips under the belt.
In regards to putting the car in 4th and turning a rear wheel, do you keep one wheel on the ground? If so which wheel do you turn?
Last time I tried this the only way to get TDC was unbolting the motor mounts from the frame and putting a floor jack under the engine. Lifted it up enough to where I could put the large socket on the damper bolt and a breaker bar to turn the engine.
Might try the wheel approach tomorrow, but have a suspicion the jack will find it's way to the front and under the engine.
tony barnhill
Great Pumpkin - R.I.P
Just outa curiosity....how much compression has that thing got?
jhorton3
jhorton3
It's been a while since I did a compression test, but I think all 4 were around or over 120.
Luke_Healey
Thanks for the tip. I'd been eyeballing the crank nut thinking "what kind of modified wrench am I going to have to make to turn that?
We pushed or pulled the car to get the distributor to a high point to set point gap on my first Sprite.
Baz
Just jack up one rear wheel, doesn't matter which, pop it in 4th, then turn the jacked up wheel in the direction of forward travel with the other wheel on the deck. That'll turn it over.
Chock the front wheels because you'll want the handbrake off.
Bugeye58
I think I'd be looking at that alternator belt for glazing. I've never failed with this method, even with a fresh, tight engine. Are you pressing on the belt with one hand, or trying to tighten the adjustment to get it tight enough? I've always just pushed down on the belt.
Jeff
jhorton3
jhorton3
New belt. Tried both ways of pressing on the belt and taking a pry bar to take what slack I can get out of it, but pulley still slips underneath.
Platinum
I've ALWAYS used Jeff's method. Should be able to turn ANY engine by hand this way with the plugs out. Tension the trailing side of the belt with one hand and it shouuld grab easily. If it's so tight you can't turn it there's "somethin' goin' on" more serious than just timing. /bcforum/images/%%GRAEMLIN_URL%%/shocked.gif
jhorton3
jhorton3
I've tried the bump start method with a remote starter switch. The problem is I always overshoot, so I want to have a bit more control to get to TDC.
tony barnhill
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If it's so tight you can't turn it here's "somethin' goin' on" more serious than just timing.[/QUOTE]
Guess my little tongue-in-cheek question wasn't pointed enough (I realized the'd removed the plugs)....if the belt slips, either the wrong belt is on the pulley (i.e., glazed, incorrect width, etc) or the pulley is worn something awful (& it that wouldn't charge is correct), or there's something wrong inside the engine.....if the belt doesn't work, I'm wondering if turning a wheel will.
Bumping the starter has always worked for me up to the last little bit then the belt trick brings it on over.
bugimike
Bumping the starter has always worked for me up to the last little bit then the belt trick brings it on over. [/QUOTE]
That is the way I have always done it too, w/o any problems!!! /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing the intake manifold Triumph 8
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
germanmichel Fixing outer tube in steering box Austin Healey 11
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
drooartz Leaking hubs, parts for fixing Spridgets 11
T Fixing Rust Triumph 16
bluemiata90 Fixing turn signals at head Triumph 3
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
M Wedge tr7 turn signal switch fixing? Triumph 1
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
tr6nitjulius General TR Sights & Sounds of things to come! Triumph 0
D Things I learned today. Spridgets 3
JPSmit things I learned today Spridgets 4
Y MGB More things that seem odd.... MG 2
swampyankee Wedge The shape of things that are Triumph 11
P Things you didn't know about your car Other Cars 10
roscoe People buy the darndest things.... Austin Healey 2
JPSmit When do you replace things? Restoration & Tools 22
S TR2/3/3A The little things Triumph 2
H weird things painted by hand with a brush Austin Healey 6
CLEAH What crazy things have you done with [to] your Healey? Austin Healey 21
kennypinkerton MGB Things I remember that I did to my MGB... MG 4
N Things you see when you don't expect it. Spotted 1
Rut TR4/4A Body repair, order of things Triumph 2
