jhorton3
Tried the wheel method and that worked out great! Painted the mark this time with some gloss white modeler's paint. Discovered I was really off. At TDC rotor is pointing at 11:45! I had a lot of difficulty fitting the drive dog gear back in last time. Now I realize I didn't do it right at all.
Since I've got the distributor out I've got a dumb question. What order bottom to top (including nylon washers) should the low tension wire and condenser be on the points post? Should it be plate, washer,condenser,points spring, low tension wire, washer, nut?
