TR6 figured out my low brake peddle problem TR6
hondo402000
Well I finally figured out why I had a low brake peddle and I doubt this will help any one else. When I redid the front calipers and new rotors and new pads I noticed I had some rattling up front so thinking I was being SMART I purchaced some springs kind of like the one you find in a ball point pen but stronger, well what I did was to pull the pin that holds the front brake pads in, I pulled the pin almost all the way out slid the spring inbetween the pads slid the pin thru the spring and put the pin back in. in essence holding the pads against the caliper. well as the brakes wore down the spring would push the pads back out and the calipers back in all the way, so I had to pump the brakes to get a good peddle, When I remembered that I had reengineered the front brakes I pulled the wheels and took the springs off and WOW I got great brake peddle, about 1/8 inch down and brakes engage.
vette Donald Healey Prominently Figured in REVS Museum Newsletter. Austin Healey 9
livinginthepast Figured out my door problem today. Spridgets 5
T I think I have it figured out...real roll bar Triumph 7
mgb4tim I think I figured it out...nope, that's not it. Triumph 3
jlaird Got it figured finaly Spridgets 1
jlaird Figured how to store parts Spridgets 1
jlaird Got it figured out I think Spridgets 8
kennypinkerton My Alfa - I figured out that thumping Other Cars 27
6 figured i oughta post an Introduction MG 28
S Wedge Finally! I figured-out the TR7 backfire problem!!! Triumph 3
F lights never mind figured out Austin Healey 4
A Auto Choke problem figured out MG 1
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
T TR6 Low Oil Pressure Light Triumph 3
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
JFS Wedge Low Coolant Light Triumph 7
O Low manifold pressure! Jaguar 8
warwick-steve How low is too low? [spring question] Austin Healey 19
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
S Low entry cost into AH ownership? Austin Healey 18
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
charleyf TR6 low speed stall Triumph 51
CJD General TR New Low for Ebay Triumph 21
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
doc50 TR2/3/3A Speedo reads way too low Triumph 13
R Low Brake Pedal Austin Healey 9
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
F TR6 Starter Relay = Low Engine Power Question Triumph 13
M TR2/3/3A Low charge with Alternator Triumph 5
B No Low Beams Austin Healey 1
