Exhaust Pipe Size
Keoke
Anybody know the O.D. of a BJ8 front pipe where in enters the muffler?
Just a thought , Can U measure the ID of the mufflers front pipe.???
B
bdcvg
No , I have the crappy chinese made Tourist trophy Moss system. The O.D. of the front pipes is 1.9. I recently burned out the 3rd set of mufflers in less than 300 miles. I am now trying to cobble up some sort of bastardized exhaust with the intent of ending up with an Abarthe tail pipe that I have been sitting on for awhile. The Abarthe will accept a 1 3/4 pipe which must be the O.D. of a correct BJ8 outlet. I don't want to buy BJ8 front pipes until I know I can make something work muffler wise. I have been fighting the stupid Tourist trophy crap for 5 years.
B
bdcvg
Moss sent the 3 sets of replacement mufflers. I called Them again after the 3rd set They did not offer to send a 4th set and at this point I don't want them. Technically I am past the original 5 year warranty anyway.
steveg
Several Healey friends and I have been running the mild steel muffler sold by Healey Surgeons. Inan recommends it as the quietest one they've found. Still sounds good after 2 years.
I've had OEM, Moss mild steel (10 years ago), Pacesetter Monza, Moss TT and now the Healey Surgeons. The latter is the best. It doesn't have the nasty resonance at cruising speed the others all developed. Am running it with Kirk headers and 1.75" Monza tailpipe with Monza tips.
I've also had several different tailpipe diameters. Found by experimentation that going back to the stock 1.25" pipe does not run quieter than the larger sizes. FWIW was measuring the decibels with a phone app.
B
bdcvg
I have 2 AP exhaust glasspacks on it now but they are 2 in. I.D. inlet so there is some leakage I would get a better set of front pipes if I can verify the O.D. of the front pipes outlets.
Keoke
Well it may be possible to take a muffler and the front pipes to a good muffler shop and have them fit the front pipes to the muffler by expanding the fitting end???
Another { Micky Mouse } way is to load the fitting ends with RTV and let it set up : But you will have a devil of a time separating them later.---😮
1 & 7/8"
Keoke
I have 2 AP exhaust glasspacks on it now but they are 2 in. I.D. and a 1 & 7/8"
Down pipe ???????
Dunno what to tell ya, K. Those are stock downpipes, probably nominally 1 & 3/4" ID, with 1/16" thick tube walls. Pipes with 1 & 7/8" ID would likely be 2" OD.
Keoke
No that delta just seemed like a big GAP to me Bob
B
bdcvg
Actually I have used the J B Weld Hi-temp epoxy with good results. Seals well and chips off if You need to remove it.
I've seen Brit mechanics on TV--inc. Edd China--use some blue goop to seal up exhaust joints; anyone know what it is? Haven't seen anything that color on this side of The Pond.
Keoke
BOB: I think we have an RTV that is blue I can vaguely remember it being recommended over the more conventional stuff but the name escapes me at the moment.???
steveg
I've used concentric sleeves and muffler cement to bridge the gap between downpipes and nose of muffler. At the auto parts store they sell pieces of exhaust pipe in various diameters which can be cut up for these sleeves. I use the SS band clamps.
HealeyRick
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
T Exhaust Pipe Hose Austin Healey 9
6 Exhaust Pipe Spridgets Classified 2
S TR4/4A How to fit exhaust intermediate pipe? Triumph 5
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
Jeepster BJ8 exhaust down pipe gaskets Austin Healey 6
M Exhaust leak at manifold to pipe bracket Spridgets 3
L Tubular header to ss exhaust pipe Spridgets 12
Nelson Sealing exhaust pipe junction Spridgets 14
drooartz More exhaust: hangers and head pipe MG 5
drooartz Bending exhaust pipe Spridgets 12
0 Wedge TR7 exhaust pipe Triumph 5
A exhaust pipe benders Restoration & Tools 8
10musketeer pulling dents out of an exhaust pipe? Spridgets 5
B BE Exhaust Pipe Spridgets 14
X T-Series Sooty exhaust pipe & loosing clutch fluid MG 0
bobh Exhaust Pipe Color Triumph 5
W Getting the exhaust pipe off Triumph 6
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
