Just a thought , Can U measure the ID of the mufflers front pipe.???Anybody know the O.D. of a BJ8 front pipe where in enters the muffler?
No that delta just seemed like a big GAP to me BobDunno what to tell ya, K. Those are stock downpipes, probably nominally 1 & 3/4" ID, with 1/16" thick tube walls. Pipes with 1 & 7/8" ID would likely be 2" OD.
Actually I have used the J B Weld Hi-temp epoxy with good results. Seals well and chips off if You need to remove it.Well it may be possible to take a muffler and the front pipes to a good muffler shop and have them fit the front pipes to the muffler by expanding the fitting end???
Another { Micky Mouse } way is to load the fitting ends with RTV and let it set up : But you will have a devil of a time separating them later.---![]()
BOB: I think we have an RTV that is blue I can vaguely remember it being recommended over the more conventional stuff but the name escapes me at the moment.???I've seen Brit mechanics on TV--inc. Edd China--use some blue goop to seal up exhaust joints; anyone know what it is? Haven't seen anything that color on this side of The Pond.
I think this is the stuff Edd China was using: > Amazon.com: Hylomar F/EXPA0HY/500G Exhaust Paste 500 G: Automotive <I've seen Brit mechanics on TV--inc. Edd China--use some blue goop to seal up exhaust joints; anyone know what it is? Haven't seen anything that color on this side of The Pond.
