TR4/4A Engine ground strap
bammons
I know this has been discussed but I could not decipher one thing. When attaching the lower engine ground strap going from the engine plate to the engine mount previous discussions indicate it attaches to the engine mount. Can it be attached to the top bolt (does this bolt go all the way thru the mount)? It does not seem long enough to reach underneath to the lower attachment. Or was I supposed to put it on underneath the mount between it and the frame (already have engine in)? Bruce
Merlin63Tr4
There's a hole in the upper rear of the engine mounting bracket (near the engine mount) for mounting the ground strap.
I hope this picture clarifies things.
M.
B
bammons
Merlin- I have the TR4A IRS frame and mine does not have that convenient hole, I wish it did so still looking for an answer. Bruce
Sarastro
It all doesn't really matter much. You just need to make sure that the battery ground has a low-resistance path to the block, through cables that can carry a couple hundred amps.
I ran a thick cable from the battery's negative pole directly to the block, then ran a smaller braided strap from the block to the frame and to the body. I like to use a threaded hole in the frame or body to make ground connections, not a bolt and nut, as the threads provide a large contact area. This is certainly not how the factory did it, but I think it is a good way to go.
B
bammons
Guys - Thanks for the answers. I know I can ground several ways but what I was looking for is the original way that the strap attached to the motor mount. When I disassembled the car 10 years ago I of course did not document much of what I did (I am a guy what else is there to say). I would like to see how it was originally attached. So if someone would complete this sentence The ground cable attaches to the engine plate on one end and attaches to _______________________ specifically on the motor mount. On top of the motor mount? Underneath between the frame and the mount? Once again thanks for the replies I just still don't have the answer I wanted. Bruce
K TR2/3/3A The engine ground strap? Triumph 6
MGTF1250Dave T-Series TD/TF Engine Ground Strap MG 4
P Engine ground strap Austin Healey 2
tmc Engine ground strap Triumph 6
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
martx-5 TR2/3/3A TR3 Engine Ground Strap Triumph 12
MGTF1250Dave TR2/3/3A TR3A Engine Ground Strap Triumph 12
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
R TR2/3/3A TR 3A Engine Ground Cable Triumph 1
T TR2/3/3A TR3 engine ground Triumph 9
S Engine Ground Triumph 3
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
