TR4/4A Engine ground strap
bammons
I know this has been discussed but I could not decipher one thing. When attaching the lower engine ground strap going from the engine plate to the engine mount previous discussions indicate it attaches to the engine mount. Can it be attached to the top bolt (does this bolt go all the way thru the mount)? It does not seem long enough to reach underneath to the lower attachment. Or was I supposed to put it on underneath the mount between it and the frame (already have engine in)? Bruce
Merlin63Tr4
There's a hole in the upper rear of the engine mounting bracket (near the engine mount) for mounting the ground strap.
I hope this picture clarifies things.
M.
B
bammons
Merlin- I have the TR4A IRS frame and mine does not have that convenient hole, I wish it did so still looking for an answer. Bruce
Sarastro
It all doesn't really matter much. You just need to make sure that the battery ground has a low-resistance path to the block, through cables that can carry a couple hundred amps.
I ran a thick cable from the battery's negative pole directly to the block, then ran a smaller braided strap from the block to the frame and to the body. I like to use a threaded hole in the frame or body to make ground connections, not a bolt and nut, as the threads provide a large contact area. This is certainly not how the factory did it, but I think it is a good way to go.
B
bammons
Guys - Thanks for the answers. I know I can ground several ways but what I was looking for is the original way that the strap attached to the motor mount. When I disassembled the car 10 years ago I of course did not document much of what I did (I am a guy what else is there to say). I would like to see how it was originally attached. So if someone would complete this sentence The ground cable attaches to the engine plate on one end and attaches to _______________________ specifically on the motor mount. On top of the motor mount? Underneath between the frame and the mount? Once again thanks for the replies I just still don't have the answer I wanted. Bruce
MGTF1250Dave T-Series TD/TF Engine Ground Strap MG 4
P Engine ground strap Austin Healey 2
tmc Engine ground strap Triumph 6
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
martx-5 TR2/3/3A TR3 Engine Ground Strap Triumph 12
MGTF1250Dave TR2/3/3A TR3A Engine Ground Strap Triumph 12
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
R TR2/3/3A TR 3A Engine Ground Cable Triumph 1
T TR2/3/3A TR3 engine ground Triumph 9
S Engine Ground Triumph 3
D Is my engine JUNK? Spridgets 4
S Engine or Tachometer Odd Problem Austin Healey 7
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
D TR2/3/3A Engine shakes as it is accelerated. Triumph 26
D Land Rover engine swop. Rover / Land Rover 0
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Pool Dad 1960 TR3 engine serial number Triumph 14
J TR2/3/3A "TR3" painted on the engine block Triumph 13
D TR2/3/3A Engine mounts Triumph 11
R Engine Number Plate Austin Healey 2
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 22
alexisrexx TR6 Engine Hoses Kit or Hose by the foot? Triumph 6
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
D Engine replacement. Rover / Land Rover 0
pairof75's General TR Circulate fluids without engine start Triumph 10
nicko Strange Engine Noise Austin Healey 7
AngliaGT WANTED - Cheap TD Engine/Transmission MG Classifieds 0
tr6nitjulius Oil flow view inside operating engine Other Cars 4
71TR6 TR2/3/3A New engine mounts not sitting flat Triumph 41
T Articles by Hap Waldrop reg engine disassembly and assembly Spridgets 1
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
J TR6 Engine rotation direction Triumph 2
G Healey 3000 cutaway display engine Austin Healey 12
B TR4/4A Engine tilt Triumph 13
R Distributor: Reassembling BJ8 Engine Austin Healey 5
S MGB MGB engine conversion MG 12
R New Engine mountings BJ8 Austin Healey 1
tahoe healey Engine Stutter Austin Healey 19
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
N Classic Mini Engine Identification British Motor Corp 2
BJ8Healeys For Sale BJ8 engine for sale Austin Healey Classifieds 0
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
H T-Series Unknown British[?] Engine MG 3
