Engine Color options
drooartz
Hap Waldrop said:
Here's look at the BMC olive green on a Spridget motor.
I recognize that motor!
tony barnhill
Great Pumpkin - R.I.P
vping said:
How about clue #2 for tht "X" head :smile:
Casting #....
12H1326
AF1H
or....
12H1326
AF1
vping
vping
Bronze
And if those are "X" heads on the blocks they are not crossflow. Hmmm...
tony barnhill
Those are "X" heads on those blocks!
vping
vping
Bronze
They all look the same with all the correct holes for bolts and sending unit. All early type and presmog. Are they taller? Not sure unless there was a non-"X" head next to it for comparrison.
This is a good one Tony.
bill_young
Hap, you need to find some sort of transparent paint so that we could get a view of all that eye candy after it's all assembled and not hide it inside some cast iron. Nice bits and great work.
tony barnhill
Putting an early "X" head & an early standard head side by side, there's no difference....the early standard head has this casting number:
12H906
AF1
I can post some close-up photos of the 2 heads side-by-side....but, I'm still not telling the real difference!! hehehe
<span style="font-style: italic">(Oh, & one of the popular MGB web sites has incorrect information/numbers in its head comparison table so you can't use it to figure out what they are.)</span>
vping
vping
Bronze
Is it an MGB head? or from another car?
tony barnhill
The "X" heads are off MG's (MOWOG)...so is the 12H906 standard head....ready for another hint?
vping
vping
Bronze
As you and I both type - I'm on my lunch searching the internet and am still drawing a blank. Continue - you're move!
tony barnhill
hehehehe......."X" heads = European castings....not offered in North America.
I'll let you go from there.
tony barnhill
NAH, this has been fun.....but, here ya go:
They were European offerings...back when there was a rash of cracked heads, lots of dealers had these sent over from salvage yards in the UK, rebuilt them & put them in customer cars. Here's the difference between them & NA heads:
1. The combustion chamber is smaller so it increases the compression ratio.
2. The intake valves are larger than any valves offered in NA heads.
3. The head flows gas smoother.
4. The area around the exhaust guides is larger than the area in normal heads so the exhaust also flows more smoothly.
When customers got their cars back (usually heads replaced under warranty) they were excited about the increased power. Remember, these are non-emission heads.
......& if you can't find an "X" head, look for an "O" head! :whistle: hehehe
vping
vping
Bronze
Other than the casting number and looking at the valves, how can you tell from the outside it is an "X" head?
Were the casting numbers in any sequence like from #123 to #456?
OK I'll take the bait, what's an "O" head. And don't tell me it's something like a left handed metric adjustable :smile:
You should move this over to the PUB. It's good reading and engine color can apply to any and all cars not just MGB's.
tony barnhill
Where the later "L" & "H" heads have those designations, these heads have an "X".
Oh, on the "O" head....hehehehe
vping
vping
Bronze
I kinda figured that what it might have been. My GT has an "H" my Roadster has the "L". No "O" that I know of. Does the "X" or "O" stand for anything like the low and high compression heads?
tony barnhill
No, the "X" symbolizes all the things I explained above...."O" is the same way for that head's differences.
Tony what is the intake valve size on a X head? What is the combustion chamber volume on a X head?
vping
vping
Bronze
Good question.
I like that gray/black engine combo BTW.
P General TR What color is original for engine parts? Triumph 7
T Austin Healey 100 engine color Austin Healey 10
maxwedge5281 engine compartment color Austin Healey 2
C Longbridge engine color Austin Healey 16
Marvin Gruber New engine color thread BJ8 Austin Healey 33
Marvin Gruber BJ8 engine paint color. Austin Healey 25
Kirk_Fisher TR4/4A Engine block color Triumph 6
NutmegCT General TR engine bay color Triumph 9
M Correct Engine Color Triumph 4
bighealeysource Engine ID tag color on BN2 Austin Healey 3
B Spitfire 1980 Spitfire engine block color Triumph 14
E TR2/3/3A 1961 TR3A Engine Color? Triumph 7
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
1 Original engine color Austin Healey 14
M Poor Dupli-Color engine enamel paint results Triumph 13
lbc_newbie Engine paint color....conundrum Spridgets 35
N 1964 sprite engine paint color Spridgets 3
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
S Mini engine paint color and pics needed British Motor Corp 9
GBRandy TR2/3/3A TR3 Engine Bay Color Triumph 5
Stewart engine color MG 4
B Engine Color MG 25
2wrench Stock engine color or what? Triumph 28
TR4 TR Engine Bay Color ? Triumph 21
NutmegCT engine bay color Triumph 23
M XK 140 engine color Jaguar 2
LeeMcKee Engine swap and frame color? Triumph 6
LeeMcKee MGB Engine Color MGB MG 2
W BE Engine What's Painted? What Color? Spridgets 29
budk1953 Engine color - REVISED Spridgets 18
MadRiver Engine color and paint? Triumph 15
I TR6 Engine and engine bay color, TR6? Triumph 4
HAN8L1965 Engine color question? Spridgets 1
Tullamore TR6 71 TR6 Engine Color Triumph 5
S TR2/3/3A Engine bay color different on tr3 Triumph 4
A Engine Color for 1976 Midget Spridgets 7
S Sprite Engine Color Spridgets 10
S Engine color Austin Healey 3
Cain Engine Color Triumph 8
C Healey engine color Austin Healey 4
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
