Engine Color options
vping
vping
Bronze
Tony - oddly enough and not knowing about X heads, one may have been dropped off last night. I'll check later and let you know. How odd.
vping
vping
Bronze
Here is the casting number on the head:
12H906
AF1
What can you tell me about it? It's presmog, big valve and has huge valve springs on it. Looks like they had to mill out the base for the springs as well.
tony barnhill
Great Pumpkin - R.I.P
It doesn't have the "X" embossed where the "L" or "H" are on later heads....its the Canadian version - almost as good...better than anything sent to the US!!
Compare it to a stock early MGB head....look inside the exhaust ports around the valve guides - is the area larger than a normal head.....take the largest US valve you can find & drop it in the valve guide & watch is be swallowed by your head.....pour a normal head's combustion chamber full of liguid wax & do the same with your head....weigh the 2 blobs of wax....yours will be heavier!
Good find!
vping
vping
Bronze
Neat info. I'll have to check later.
vping
vping
Bronze
I did notice that the head does not have an X, L or O. There is actually nothing in that spot. I think the head was milled out for larger valve springs - really large springs. It also looks like it was milled out for larger valves as well but they compare in size to the valve on my '74. How big you talkin' bout Tony?
tony barnhill
I'll have to flip my 12H906 over to compare...all I really know is what the old guys tell me about that particular head....do you know Dick Leuning up in Wisconsin?
vping
vping
Bronze
No can't say that I do. I'll snap a photo of it. I beginning to think it might be a modified B head without a letter on it.
tony barnhill
Yep - Dick's the one who turned me on to "X" heads & got me searching for them....he's also the one who told me about the attributes of that Canadian head.
P General TR What color is original for engine parts? Triumph 7
T Austin Healey 100 engine color Austin Healey 10
maxwedge5281 engine compartment color Austin Healey 2
C Longbridge engine color Austin Healey 16
Marvin Gruber New engine color thread BJ8 Austin Healey 33
Marvin Gruber BJ8 engine paint color. Austin Healey 25
Kirk_Fisher TR4/4A Engine block color Triumph 6
NutmegCT General TR engine bay color Triumph 9
M Correct Engine Color Triumph 4
bighealeysource Engine ID tag color on BN2 Austin Healey 3
B Spitfire 1980 Spitfire engine block color Triumph 14
E TR2/3/3A 1961 TR3A Engine Color? Triumph 7
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
1 Original engine color Austin Healey 14
M Poor Dupli-Color engine enamel paint results Triumph 13
lbc_newbie Engine paint color....conundrum Spridgets 35
N 1964 sprite engine paint color Spridgets 3
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
S Mini engine paint color and pics needed British Motor Corp 9
GBRandy TR2/3/3A TR3 Engine Bay Color Triumph 5
Stewart engine color MG 4
B Engine Color MG 25
2wrench Stock engine color or what? Triumph 28
TR4 TR Engine Bay Color ? Triumph 21
NutmegCT engine bay color Triumph 23
M XK 140 engine color Jaguar 2
LeeMcKee Engine swap and frame color? Triumph 6
LeeMcKee MGB Engine Color MGB MG 2
W BE Engine What's Painted? What Color? Spridgets 29
budk1953 Engine color - REVISED Spridgets 18
MadRiver Engine color and paint? Triumph 15
I TR6 Engine and engine bay color, TR6? Triumph 4
HAN8L1965 Engine color question? Spridgets 1
Tullamore TR6 71 TR6 Engine Color Triumph 5
S TR2/3/3A Engine bay color different on tr3 Triumph 4
A Engine Color for 1976 Midget Spridgets 7
S Sprite Engine Color Spridgets 10
S Engine color Austin Healey 3
Cain Engine Color Triumph 8
C Healey engine color Austin Healey 4
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
