Rut
I have reviewed every wiring diagram I can get my hands on and the one I posted previously had green to #1 and black/green to #2. The Bentley manual, Gerard's Garage, and a few others show what Alan says...green to #2 and black/green to #1. The green wire comes from the fuse box, the black/green wire comes from the switch which has 3 black ground wires connected to the other post. In my mind that gives you 1 hot wire (green) and 2 ground wires (black/green from switch) and the black ground wire from the motor case. Thoughts?Switch the G/B to # 1 on motor and G to # 2!! Had the same problem!
Thanks, a very nervous when it comes to Electrickery Rut
Hi Guest!
