Differential and rear suspension
neilert
Winter is here, and I'm going to work on the healey's rear end. It's a Longbridge BN4. I don't want to restore the car, but would like to make sure it's safe. Currently the axle hits the frame on rebound. The repairs will take at least a few months.
The rubber bump stops are missing and bump stop boxes are rusted out. The left rear sits 2" lower than the right rear, and both sides ride too high. I'll post some photos and dimensions as I go. Here's the rear right side sitting too high.
The pinion seal also needs replaced, and we'll see if the bearings need replacement as well. Here's the oily differential before removal.
While all of this is apart, I will replace the driveshaft's u-joints and replace the handbrake cable and old interior carpet. The seats, carpet, and transmission tunnel came out in about 30 minutes. This stuff always comes out faster than it goes back in.
This is a photo of the rear left spring front bracket, which is welded in crooked. The frame has some previous damage and rough repairs as well.
Here's the right shock bracket, also with rough welds. I'll try to take some frame measurements tomorrow night to compare to the factory drawing for replacement.
Feel free to let me know if you see anything major that needs attention- I appreciate the help.
nevets
I'm not an expert but in light of all the apparent rust, it may be a good idea to evaluate the integrity of the frame and other structural elements.
dougie
I'll second that suggestion. Clean and degrease completely to a sound substrate.
Cutlass
I spent a year just addressing issues like yours. Don't compromise on safety. If you find yourself saying that your repair is "good enough," it's not.
N
neilert
Thank you for the suggestions. I agree that the frame is going to need a lot of work. As it is cleaned, checked, and measured I'll post photos. Yes, the chassis outriggers are bent. Is Kilmartin's the way to go for the frame pieces?
Cutlass
I would not use any frame parts other than Kilmartin. No question. I replaced all four outriggers, front and rear crossmembers, sills, rockers and all floor and trunk sheetmetal. Kilmartin is the way to go.
N
neilert
Cutlass, were your frame repairs done with the body on or off? This looks like it is going to be difficult with the body on. Any photos and lessons learned during the repairs would be appreciated.
GregW
Platinum
Hi Neil,
One of the measurements you should check is the center to center of the holes on the leaf spring mounts (front to back). They should be 35½". If they are closer, that may be one reason the axle sits high.
N
neilert
Thanks for the hint GregW. The center to center spring mounts were 35 1/2" on the left and 35" on the right, which would make the right axle sit higher. Both outriggers need to be replaced.
Cutlass
Neil: I did all my replacement with a fully disassembled car. That method has plusses and minuses. The big plus is ease of access. The big minus is difficulty with alignment without a frame jig. If you can weld upside down, and use a wire feed welder, it's doable. I used a tig welder, which is great for thin metal and beautiful welds, but is not easy.
I have seen some very good repairs done without disassembly of the entire car, so it can be done. But always, always pare back to good metal. I also took the time to fabricate and install extra gussets for the rear outriggers and vor the cruciform, as well as boxing the motor mounts. I do have photos, but am not yet able to post them. Maybe when my son comes home for Christmas he can get me hooked up. Jim
Cutlass
Neil: I welded the new spring mounts onto the rear outriggers before attaching the outriggers. That makes the mounts much easier to weld. FWIW
N
neilert
Welding the spring mounts on first sounds like a good idea for quality welds on the bench rather than upside down on a cold floor. I'll clamp the parts to the frame first to take measurements. I have mig and tig welding equipment, but will use the mig for this because I have more experience with it. I haven't been able to touch the project for a few days- work has been busy. Hopefully I can start working on the frame this weekend.
Cutlass
Be sure to check the frame where the outriggers mount. Mine had quite a bit of rust damage, so I had to cut back on the outside part of the frame to weld in a patch before welding in the outrigger.
GregW
Platinum
Well Neil, how you gonna get them quality welds from the outrigger-to-frame? :smirk:
I'm thinking you'll need to remove a small portion of the floor boards to get the outrigger welded to the top of the frame. Maybe remove just enough so you can do the vertical welds from the top also. Then weld in patch pieces for the floor.
Cutlass
Greg is right. Each outrigger has four sides to weld, one of which is just below the floor pan, not reachable with the pan in place. So without a rotisserie, you have two vertical welds, one overhead weld and one weld you must cut out the floor pan to access. The outrigger also has these issues. I would also suggest welding on the gussets after the outrigger, as the gusset conceals the adjacent vertical weld on the outrigger, thus if you try to attach the gusset to the outrigger first, you can't make that vertical weld on the outrigger/frame joint.
vette
Hi Neilert, I just finished doing my frame and floors, so I guess I'll throw in my two cents. You have a pretty big project ahead of you so don't fool yourself. Once you take it apart as far as you are going to, don't short change the work because the structural integrity is severly deminished by all the rust. One spot I must emphasis is that I found that even though my floors didn't look that bad, they were in reality, TERRIBLE. then once I cut out the floors I found that I had some places on the top of the frame rails that were rusted thru, because the floors trap moisture and garbage on top of the frame rails. You will be doing alot of welding upside down. That's just the nature of the work. I personally put the spring perches on the outriggers after I welded in the outriggers. I took copious measurements before I cut anything apart. With new outriggers and gussets welded in, I dupicated the measurements and welded the spring perches in. If you put the perches on first and you get the angle of an outrigger off just alittle, you will have the perch off alot. If the perch is put on last, you could compensate for any variable you may have created in setting up any other piece. I have some good clear pics but I not sure I know how to get them on the forum. I will try later.
Good Luck.
vette
Neilert, Be very deligent in placing the rear outriggers. Look at how they are attached to the outer body at the inner sill. That outrigger must be placed with exact measurements so that you don't force the body high or pull it low. This locating will affect the height of the spring. Take measurements from places that will not be affected by your disassembly, ex, being the top of the inner sill. I welded in a piece of 1 and 1/2 inch angle iron across my cockpit about 10" above the outriggers to use as bracing but also to use as sort of a datum line to take measurements from. I used 1 & 1/2" so that it would not flex or bow giving me false references later on.
John Turney
FWIW, but "just replacing the outriggers" led to a complete disassembly and "restoration" of my Longbridge BN4. The outriggers led to the sills and floors being replaced.
Also, I found the new spring mounts were thinner than the old ones, so I welded a brace on top of the outriggers and spring mounts to beef them up to minimize side-to-side flex.
T Rear/Differential "Clunk" Austin Healey 2
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
J TR6 Differential / Rear Axle Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
D TR2/3/3A rear shelf differential dome Triumph 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
KVH General TR Rear Differential Seal Triumph 7
C TR2/3/3A Rear differential Triumph 29
A Rear Differential Concern??? Triumph 11
T Spitfire Spitfire differential rear bushings Triumph 5
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
zschicago Replace rear differential gasket? Austin Healey 12
R MGB MGB Tube Type rear differential MG 0
R use redline mt-90 in 1275 rear differential? Spridgets 3
I rear axle to differential flange bolt grade? Triumph 8
N Rear Differential Rebuild Triumph 9
KVH Rear Differential Overflow Valve Triumph 3
Lin Rear Differential bearings Austin Healey 2
C TR2/3/3A Broken TR3 rear differential Triumph 9
G Rear Differential - Pinion Gear? Austin Healey 3
jerrybny Differential/Rear Axle Gaiter question Triumph 6
S TR2/3/3A when rebuilding a differential Triumph 9
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
