diamond in the rough?
TR3driver
Great Pumpkin - R.I.P
He's also badly mistaken about what he has. That's at least a late TR3, most likely an early 3A; not an early TR2. Note the Girling MC, wiper motor on LH side, H6 carbs, high port head, partially recessed headlight, chrome grab bar, paint on the instrument panel, inner door handles inside the pocket instead of outside. Some of those things might have been changed, of course, but it's not likely they all would have been changed.
Less than 100 cars were made in 1953, so if it really was a 53, it would be worth restoring. As it is, it's hardly worth dragging home to part out.
BTW, the routing of the speedo cable indicates no OD.
JohnB
Bronze
Randall hit it on the head again.
That's definately a TR3a.
tdskip
That car will need LOTS of work. If the inner panels in the engine bay have gone, everything else will be a mess too. You never know but...
Banjo
Ooof! .. parts car. TR3A not a 53. It's awful, but not awfully rare. Would be worth getting very cheap if the engine is not seized, otherwise, there's not much of anything there.
HerronScott
Looks like there might be a rusty hardtop as well.
Scott
bugimike diamond in the rough! Spridgets 7
SilentUnicorn E-Bay diamond in the rough Spridgets 7
Editor_Reid "Fuel Diamond" Gasoline Treatment Austin Healey 19
aeronca65t Jaguar Diamond Missing-Reward! Jaguar 1
T TR2/3/3A rough running after 20 min shutdown Triumph 9
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
N Stuck Needle Valve - Rough Running Austin Healey 15
C Rough Idle - What to check? Austin Healey 12
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
B Thoughts...rough running at cruise. Austin Healey 3
M TR2/3/3A Engine rough on acceleration Triumph 19
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
N Runs Rough Under Load Spridgets 15
Gliderman8 General TR Rough looking '67 Vitesse Triumph 7
JPSmit Rough Bugeye hood Spridgets 0
M Rough Idle MG 15
K Rough patch inside bore of SU? Triumph 2
W Mighty rough..... Spridgets 1
justin_mercier Post-War Other 63 Herald in rough shape, MA craigslist Triumph 2
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
T Rough clearance checks Spridgets 2
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
vping Running rough MG 9
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
D XJ8 rides rough Jaguar 5
MGB922 Rough Idle MG 13
A rough running after long idle or long low rpm driv Triumph 1
D GT6 Rough GT6--your thoughts? Triumph 9
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
T Rough budget +/- for 1275 cylinder head overhaul? Spridgets 10
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
RickB MGB 70 MGB runs rough - sputters & backfires esp. cold MG 44
tahoe healey surging and rough running Austin Healey 20
