jvandyke said:Got all old dash out and mocked up the new one. Looking nice to me so far. Not sure what I'll do with the hole for the windshield washer. What was that thing originally? What type of switch. I might just make it a pull switch set up for a washer motor, but I won't hook it up to anything. Or I could put my light there that I rigged up to come on when my electric fan kicks in....thoughts?![]()
scoutll said:First photo shows how to access the two end attachment points. They are in the hollow gap at the end of the dash. You have to pull the door seal away to access them. The central ones are through supports and are harder to get to.
Second Photo is a close up of the upper right end.
Third photo shows an overall view of lower support rods. You can also see the upper right attachment point in this photo.
Gundy said:Perhaps an over ride for the electric fan? I have a pull switch which lights to indicate it is on for my fan manual switch.
Mostly it is off and I rely on the thermo switch but if
I'm say getting ready for some serious driving I just pull
the switch and the electric fan just runs till I push the switch closed. Kind of a security blanket for when I'm stressing the car.
I also had a "spare" hole in my dash. I just installed a
simple on/off switch to match the turn signal switch as a dummy switch.
It's there if I ever decide I need another switch for something.
jvandyke said:Gundy said:Perhaps an over ride for the electric fan? I have a pull switch which lights to indicate it is on for my fan manual switch.
My electric fan has a three way toggle; sensor/on (over ride the sensor)/all off. I rigged a light so if it turns on, either by the sensor or manual, I know it. I also rarely need the fan.
That was my thought on the extra hole too; mount a switch for future use, some day I can reinstall the cheap electric windshield washer pump if ever get "bored" and am looking for something non critical to do on the car.....fat chance!
scoutll said:If you want, I can try emailing the pdf for the body section out of the BMC manual.
Gundy said:One day I may do that to mine. I hope to find a use for that dang switch one day too.
