Now see Dale, this is exactly what I was talking about. There were three suggestions given, and you looked at one of them and decided that you can't stand what's going on. Yes, pulling the engine is extreme, but it is an alternative. That same poster suggested bolting up the tranny WITHOUT the clutch...a very good suggestion. It will be easy to slip in place, and only needs to be attached with maybe four to six bolts (after all, there were only three holding things together to begin with), lowered down onto the mount (won't even have to bolt it down), and away you go.
TR6Bill's approach also has merit, as that is another good way to handle the situation, but it does require some fabrication.
So, decide which is easiest for you, and stop dwelling on how lousey things are getting. We are here to help you, but at this time we need to have one or two guys step up and guide the Tinster through this behind the scenes.
Dale, you need a focused approach to this.
