TR2/3/3A Control Head wiring
charles brooks
Hi All,
I just purchased a new control head from Roadster Factory and since my original wiring is fine is it possible to remove the wiring from the new unit and connect the originals to it? I'm replacing because the turn indicator won't cancel and the bakelite is cracked but as I say the wiring is all good and I prefer to not take the chance of getting the wiring lost either coming or going in the black hole of the stator tube.
Thanks for any information
Charles
John_Progess
Charles,
Yes you can use the old wires if they are in good shape. Just be careful when you take the new control head apart and write down the location of the wiring connections before you remove them so you can attach the old wires in the correct location. There are several small parts in the control so be careful!
John
TR3driver
Great Pumpkin - R.I.P
You'll need to partially disassemble the head, though. The horn wire attaches to what appears to be a stud, but is actually a long screw, so you'll have to pull the horn button off to hold the screw head while you tighten the nut.
Note that the wire terminals have little tabs that fit into holes in the Bakelite.
Kleykamp
It's been a while since I was into the control head, but I'm pretty sure it has to come off in order to get it apart enough to get to the wire connections. All the screws holding it together are on the steering wheel side.
charleyf
There are as well some springs in there that complicate the reassembly of the unit. Also because of the short wires coming out of the tube you will be working in the car over the steering wheel. Not a great place to work with spring loaded things and multiple layers of parts.
Alternately the only real problem of changing the unit as a whole with wiring is getting the new wires fed down through the stator tube. By using a wire connected to the old wires as you pull them up through the tube you can attach the new control head wires to the wire fed up the tube and pull the new wires back down back down. I will admit that I have had some trouble getting this step done. But I think next time I will use some shrink wrap to cover the ends of the wires and the pull wire. You want to make that end of the wires as small as possible to get it down the tube.
Charley
TR3driver
You should be able to leave the switch compartment assembled, which is where the "complicated" springs are. Only the back plate (with the stem to engage the stator tube) and the horn button/cover need to come off the switch. There is one spring that goes under the horn button, but it's easy to deal with IMO.
Basically, you stop here in the disassembly process
DSCF0006_crop1.jpg~original
DSCF0007.jpg~original
C
charles brooks
Wow!! My first question and such quick and knowledgeable replies. Thanks so much to everyone. I think I'll try to just use my original wiring since it's in excellent condition and for the reason of naivety my confidence is higher to take the head apart rather than try to pull the wires through the tube. I'll report back.
Thanks again
C
charles brooks
Thanks so much for the photos and your information and now knowing I don't have to get into the difficult spring department I'll definitely try this approach.
Got_All_4
I'm confused as to what you would gain from using your old wires verses the risk of ruining your new control head if your not experienced in dismantling one?
BillyB62
Charles,
I think you'll quickly see that some of the members on this forum are a walking encyclopedia of TR knowledge. Over and over it amazes me how quickly and accurately many of these folks nail the answers to questions almost on a moments notice. I truly think they enjoy sharing to keep our "hobby" alive.
sp53
Randall’s picture is spot on and the only thing I would add is to move the selector over to each nut as you loosen each nut. This will keep pressure on the brass nut because if I remember correctly, the brass stud can fall out of its key way when the nut is off the stud as you swap the wires out. I have done it the way you are doing it, and you will see more as you take apart the new one. TRF parts are often of high quality and their wire looms are probably the correct size and putting them through would/might not be difficult either, so either way should work. There were some wirer looms around a while back that were just a fuzz bigger and they were a nightmare to get through the stator tube. I tried it once and it was a disaster, so if you go new look real close at the wirer size. I think it is Macys Garage that makes the corrected size wire loom to fit the stator tube hole if you need it and again TRF probably has it correct.
C
charles brooks
I would actually prefer to replace the entire unit including the wiring but am concerned that pulling the wiring through the tube sounds more difficult that changing the wires. A possible pitfall to changing the wiring is that I haven't taken the new unit apart enough to see if the connections are screws or if it has soldered connections. Do you know by chance. It's from the Roadster Factory. If soldered I would definitely opt for replacing the entire unit.
Thanks for any information.
TR3driver
FWIW, The control head harness I got from TRF some years back was definitely larger than the original, and difficult to get through the tube. The individual wires appeared about the same, but the cloth covering was at least twice as thick as the original. I finally had to use wire pulling lubricant to get it through. Unfortunately, the lubricant has dried out and effectively glued it in place. I will probably have to destroy the harness to get it out again.
If I do it again, and find the same problem, I plan to strip off the cotton cloth and replace it with modern poly sleeving. The poly is thin and slick, and while clearly not period correct, looks pretty good IMO.
DSCF0029_crop.jpg~original
mgedit
I had my control head apart and the advice above is all good. There is an online article covering control head disassembly. I was concerned about getting the wires through the tube too, but in my case it was one of those jobs that caused lots of concern in advance but actually went very easily. Make sure the wires are all different lengths so that they "pack together" to minimize diameter of the bundle. I believe I used some thin mechanics wire to gently pull the wires trough the tube. Likely good idea to make sure the inside of the tube is very clean before starting. Cheers, Mike
bobhustead
I used the TRF unit. The wire lengths were staggered so the bullet connectors followed each other in single file, rather that being clumped at the same place. Installation instructions included a tip to slightly twist the loom while feeding it down the stator tube. Installation was quick and easy. I used a single pull wire taped lightly to each bullet.
C
charles brooks
I prefer to use the new unit and new wiring but am concerned that getting the harness to go through the tube may be more difficult than swapping the wires from old head to new one. Perhaps I've read too many horror stories of wiring getting stuck. I would definitely go with trying to get the new wires through the tube if the wiring connections on the new unit are soldered rather than screw connections. I haven't taken the back off yet to see how it's made. Anyone know??
Thanks
sp53
There could be a 3rd path here because often the stator tube is broken or weak. You could get a new stator tube from that Macys Garage and fit the 2 together and pop it in the car that way. Kind of prices I think they are 50bucks, but almost every old tube I have seen is going to break or broken at the keyway slot cut in the tube. So, I suggest at least loosening up the olive nut and sliding your tube up a couple inches and having a look where the head keys into the tube.
C
charles brooks
I decided I should try getting the new wiring through the tube and guess what??? it took all of 15 minutes using some picture hanging wire pulled through with the old wiring and then the picture wire taped to the new wires for the return trip...
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Got_All_4 TR2/3/3A Control head wiring help Triumph 11
B Another wiring question 57 smallmouth control head Triumph 2
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
71TR6 TR2/3/3A Control Head horn contact Triumph 7
Lin Another Trafficator/Control Head Question Austin Healey 10
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
C TR2/3/3A Control Head Rebuild Help Triumph 1
trotti Control head / trafficator questions Austin Healey 14
B Stator/Traficator [Control Head] Question Austin Healey 2
J TR2/3/3A Correct trafficator control head? Triumph 4
K TR2/3/3A The Control Head on the Steering Wheel Triumph 3
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
G TR2/3/3A Control Head How to Repair Triumph 5
G TR2/3/3A Control head Lubricant? Triumph 3
Y Fault in Steering Wheel Control Head in BT7mk1 Austin Healey 3
G TR2/3/3A Control Head Video Triumph 3
R trafficator/control head rebuild Austin Healey 10
luke44 TR2/3/3A Control Head Ground? Triumph 1
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
Superwrench Steering Control Head Assembly Austin Healey 4
Tinkerman 60 TR 3 A Control Head & Steering Wheel Triumph 9
S control head canceller 180 out Triumph 3
J TR2/3/3A TR3A control head question Triumph 4
tmc TR2/3/3A TR3A control head disassembly Triumph 4
DavidChandler TR2/3/3A Tr3A Control Head Triumph 16
K TR2/3/3A Internal view of a tr3 control head Triumph 7
Gordon_Dedrick Control Head Screws Triumph 5
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
AweMan Control head question Triumph 4
donbmw link to control head rebuild Triumph 5
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
P Steering Control Head Triumph 2
G Adapting adj. wheel control head to non adj. wheel Austin Healey 5
J TR2/3/3A TR3 control head internal pictures? Triumph 11
