Hi Guest!
Yes. I ordered the book 10 days ago. The pdf on the internet is not as helpful. I have the BJ8 Bolt/Screw chart/codes and have studied them.I think the best way to help you find some of your answers would be to have a BJ8 Parts Book and a copy of the Bolt/Screw codes that identify the length n finish of all the screws and bolts. I did that when I was putting my BJ8 back together and it saved me a lot of grief and my Healey is NOT a 100% Concours car by ant means with al, of the improvements that I made to it including a Jule Frame.
Hello again Reid.
Hello again Reid. Took and implemented all your direction and things are going well. More issues have come up and would again, appreciate your sage advice, if you would pretty please...(I have read, many times, the '21 and '22 Concours Guidelines and do not ? believe the questions below are covered, although I could have missed it or not have a clear understanding of that portion)
The nuts on the door hinge pillar are “weld nuts” permanently welded to the part. You could replace them, but the fender (and door) would have to be removed. Welding new ones on would obviously burn the paint off1. Are the nuts on the two bolts that fasten the door stops, welded on the other/inner side? If not, how to change those bolts to get up to correctness?
Yes, washer and lockwashers. Nuts are “weldnuts” on the wheelarch. There are welded studs on the seat shelf.2. Do the bolts that fasten to the bump box (rear wheel wells) have washers under the head? Flat? Lock? And, I assume the nuts on the other side are welded in position?
Zinc plated.3. Are door strikers polished gloss finish? If not, what would they be? Mine are a dull metal.
Completely gloss black.4. Is the buckle that is attached to the leather strap that keeps the spare tire in place, completely black gloss or just the "rolling" piece on the top of the buckle?
I might have a battery tag. I don’t think they are reproduced anymore. It’s a discretionary deduction. Not more than a ½ point.5. If I do not have the red battery switch paper tag, will I get a point reduction? If so, any suggestions on where I might obtain? Tried the usual Moss, AH Spares, ebay.
People have been arguing about this forever! I always put the nuts inboard and have never been called out for it.6. Which way (head in or out) does the 4 bolts that attach the bonnet to their hinges go?
The Tenax studs in the rear panel and machine thread with a 10-32 nut (5/16AF).7. On my dangling strap (about 1' thick by 7" long) problem, attached to the front part of my hood cover *when in down position". My research indicated that it must have a tenax/snap set up where the tenax is fastened to the inside back wall so that the strap will pull the cover forward when the top cover is on. But, the tenax appears to have a bolt shaft and not a screw to fasten. Is there hiding somewhere in the wall (and therefore under the trim) a pre-drilled hole the tenax goes into? How do I fasten the studs?
These buffers are the same as the ones for the hood (bonnet). You’ll see a couple of holes on the inner wheelarch panel. One is about 3” from the boom [I suspect he meant "bottom"] and the other about 9” above that. They’re meant to keep the fender from hitting the inner wheelarch. They were installed before the car was painted, so they get painted.8. The Guidelines refer to two rubber buffers fastened with split rivets and washers, attached to the outer rear edge of each of the front inner wheel arches. I looked there and cant fathom what and where. Any help?
What's the difference between a colonoscopy and a getting your Healey judged by the Concours Committee? You get to sleep through the colonoscopy!Well, that is it for me. Your advice and any colonoscopy humor would be appreciated. Thanks.
This is a site which will be helpful, > Service Parts Lists - Austin Healey 3000 (Series BJ7 and BJ8) <Hello again Reid. Took and implemented all your direction and things are going well. More issues have come up and would again, appreciate your sage advice, if you would pretty please...(I have read, many times, the '21 and '22 Concours Guidelines and do not ? believe the questions below are covered, although I could have missed it or not have a clear understanding of that portion)
