AngliaGT said:-
"Fight fire with Napalm!"- Doug
DNK said:Shannon,first thing,put those 55/60 in hiding and buy 55/100's
In that case, how do you protect the wiring upstream of the switches ?Scott_Hower said:I have all 4 beams fused independantly on my MGB.
TR3driver said:In that case, how do you protect the wiring upstream of the switches ?Scott_Hower said:I have all 4 beams fused independantly on my MGB.
Unless of course there is a short in the factory wiring.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The relays do the heavy lifting; they are wired directly to the alternator.[/QUOTE]Meaning those wires are also not protected.Scott_Hower said:The factory switchgear upstream no longer carries any current
As far as I'm concerned, it already did for me. Just the tiniest sharp edge in the steering column, but after 35 years it finally wore through the insulation into a big brown (always hot) wire. Glad I wasn't on the freeway at the time, because the cabin filled with smoke pretty quick. And this was on one of the very few Triumphs that came with 4 fuses for the headlights.LastDeadLast said:Time will tell, right?
Meaning those wires are also not protected.TR3driver said:Unless of course there is a short in the factory wiring.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The relays do the heavy lifting; they are wired directly to the alternator.Scott_Hower said:The factory switchgear upstream no longer carries any current
Right. Which has nothing to do with how much it will carry if there is a short between it and the relays. Or how much will flow if there is a short between it and the battery.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]the risk of fire is FAR less than what originally came from Abingdon/Canley.[/QUOTE]A little less, no doubt. But the original switches actually act like fusible links to some extent, so I wouldn't call it FAR less.Scott_Hower said:Oh please. The headlight switch might carry a a few thousandths of an amp. Just enough to hold the relay coils closed.
A little less, no doubt. But the original switches actually act like fusible links to some extent, so I wouldn't call it FAR less.TR3driver said:Right. Which has nothing to do with how much it will carry if there is a short between it and the relays. Or how much will flow if there is a short between it and the battery.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]the risk of fire is FAR less than what originally came from Abingdon/Canley.Scott_Hower said:Oh please. The headlight switch might carry a a few thousandths of an amp. Just enough to hold the relay coils closed.
