TR3driver
Great Pumpkin - R.I.P
Not at all, Scott. I'm just trying to point out the false sense of security from those relays & fuses you've added. You've still got an unfused hot wire running through the dash, and the fact it carries almost no current normally has nothing to do with what happens if it manages to short to ground.<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I'm sorry you melted your dash.[/QUOTE]Actually not bad at all. I also have a disconnect and managed to yank it fairly quickly, so the only real damage was the connector at the base of the steering column and the harness to the lighting switch.Scott_Hower said:You're obviously bitter and no amount of logic/common sense will change your mind.
Likewise, obviously your mind is made up; so I won't try to confuse you with any more facts.
