TR2/3/3A Choke Cable Detent Device
mastaphixa
Bronze
So I'm replacing the choke cable with a Moss part (OE Type) and I rotated the little spring collar that keeps the detent device in place and it flew out and hit my tee shirt just about belly button high. I never heard it hit the floor, bounce off of anything. I have no idea what it even looks like. Can someone at least describe it to me, a picture would be great. Is it ferris metal so I can at least use a magnet to help in my search of the shop floor?
CJD
The best description would be "wedge" shaped. I lost mine too, and fashioned one from a section of 1/4" brass welding rod. One side is curved, conforming to the shape of the collar. The other 2 sides are straight, forming the wedge. At least that's how I filed my replacement. Like you, I never had a chance to see the original that flew away!?!
I even bought a replacement cable, assuming my little wedge would eventually fail. It lasted more than 4 years until I sold the car...so the "new" cable will go on the TR2.
M
mastaphixa
Bronze
Thank you John. I now see why I couldn't find it or even hear it hit the shop floor when it bounced off of me. I made my replacement out of standard K and S brass strap that measures .032 in thickness. In the attached picture you can see I made very small 1/2 moon key that will fit under the spring clip once it is slipped over it and provide the detent function on the choke cable. Took a little filing to get it right, but now I know. IMG_2550[1].jpg
CJD
There you go! The trouble is that until you have moved that little clip and watched the detent go flying out once, you have no idea it is in there! Bet you never let it happen again...I know I won't...
mrv8q
Here's my current Choke Cable Detent Device
M
mastaphixa
Bronze
I was using the MK1 Clothes Pin Detent as well, but the owner wanted the cable replaced so.......
mrv8q
Hah! The CPD Mk1 works just fine for me. When I'm not using it, I clip it to the tonneau cover.
I have had my car for over a dozen years, and the choke detent has never worked. Geo told me about the CPD...
mrv8q
So that makes Masta and I OCD I guess...
Maybe so, but you have properly working choke cables, and I have a cute wooden kluge...
B TR2/3/3A Choke cable detent Triumph 4
R TR6 TR6 Choke Cable Triumph 11
D Choke Cable Length Austin Healey 0
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
F TR2/3/3A Choke Cable Problem Triumph 29
edkap2002 TR6 72 tr6 choke cable Triumph 4
TRMark TR4/4A Choke Cable Routing Triumph 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
Rob Glasgow Choke cable turnion Austin Healey 8
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
E T-Series MG TD choke cable MG 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B TR2/3/3A choke cable attachment Triumph 14
B BJ8 choke cable Austin Healey 0
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
KVH TR4/4A Choke Cable TR4A Triumph 5
W New choke cable install Triumph 1
af3683 TR2/3/3A New TR-3 Choke Cable Triumph 7
Tinkerman TR2/3/3A TR3A Choke cable hook up Triumph 3
J TR4/4A TR4 Choke Cable Routing Triumph 4
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
af3683 TR2/3/3A TR3 Choke Cable Triumph 17
bugedd Choke cable repair help Spridgets 3
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
R choke cable Spridgets 6
jsfbond Choke cable [square knob] Triumph 0
UmmYeahOk GT6 Choke Cable for a 67 GT6 Triumph 4
Editor_Reid Needed: Choke Cable for BN2 Austin Healey 0
memphis Choke Cable Austin Healey 1
M stromberg choke cable config. Triumph 8
M stromberg 175 choke cable? Triumph 2
G Which choke cable should I use for euro 1500 carbs Spridgets 8
T ID a choke cable Triumph 3
H Choke Cable Return Austin Healey 14
T Choke cable Triumph 1
Tinkerman TR2/3/3A TR3A Choke Cable Questions Triumph 2
jvandyke choke cable length Spridgets 11
H Throttle cable and choke cable holder MG 3
drooartz Choke cable connection? Spridgets 8
Nelson Choke cable connection? Spridgets 5
J TR6 75 TR6 choke cable problems Triumph 4
