MGTF1250Dave
The older type graphite coated cork seals work very well and are some what compressible. The graphite lubricant makes pulling out the choke easier and allows the return spring to move the jets up against the mixture adjustment nut when the choke is released. If the are allowed to dry out however they can crack resulting leaks. This usually occurs after the car has sat idle for an extended time.
The o-ring solves the problem of the cork seals drying out. The draw back is that the neoprene o-ring is not as "slippery" as the cork seals. They need some type of lubricant to allow the jets to move when using the choke. Silicone encapsulated o-rings include the lubrication need for the use of the choke.
Do the jet move up and down easily when you use the choke? Sometime if the o-rings aren't lubricated they will grab and roll along the jet.
