@ Scott, the car needs to be smogged and registered no later than may 5th, that is my deadline. Also, your package just came in the mail, I sure do appreciate all your help Scott, thank you for the parts, I'll get this darn thing running some how. On a side note, it looks like the post office wasn't very gentle with the package, the flywheel on the smog pump was shattered into pieces and the pieces came out when I opened the bag. Luckily! The flywheel on the old smog pump I had is just fine, so I can switch that out quite easily. My main concern right now is if I get a carb rebuild kit, rebuild the carb but it's not good enough and find out I need to send it off for a several hundred dollar professional rebuild. I hope that's not the case... Another thing that is overwhelming is knowing exactly what little bits, bolts, washers, clamps, hoses, etc I might need to order from spitbits is. I wish there was a store you could just go buy the stuff from in person when needed.
More frustrations have arisen as well. The back left tire sounds like the brake pad is rubbing or there's something up with the rotor. I've had this sound before on other cars and it was always related to the brakes. Not quite sure what to do about that...
