Brake Lights But No Turn Signals
Martinld123
Bronze
Well all was great with new LED turn signal and brake lights until today. I got all of the LED's and proper resister for each side from Moss Motors and all was well for couple of weeks. Now when I turn on left or right turn signals on at steering wheel only center indicator light comes on in Dash with no flashing and stays on for either right or left but with no turn signal lights at all at rear of car. No light at all at back of car when trying to use turn signal. Same with front turn signals. My flasher unit is brand new from Moss. I hope problem is not in steering column. Will start looking tomorrow. Any ideas? Thanks Marty
vette
I haven't been following what you have been doing so I am not sure what year Healey you have. But from your avatar it looks like a 100. If so you have a stop light/ turnsignal relay on the the left from inner fender apron. I you say that you have no lights at the rear, (no running lights or anything) and you have the same at the front when you try to use your turnsignal switch at the trafficator on the steering wheel, then please know that the trafficator switch on the steering wheel switches the relay to the right or left. Look at the drawing I have attached and see that terminals 4 and 8 on the relay box are the coils that pull the relay either to the right or left. With ignition on I would check to see if I have voltage on terminal 4 if the trafficator is pushed to the left. And if I have voltage on terminal 8 if the trafficator is pushed to the right. If you do not have voltage on either 4 or 8 then it could be the trafficator or the connections at the base of the steering column (at steering box). the power for the trafficator is the green wire at the base of the steering box and it is ultimately derived at #4 terminal of the fuse block but it is sometimes run from the fuse block to the round flasher unit to terminal 'B' and then run to the bottom of the steering box. The other issue which you say is that you have no running lights either. The running lights have nothing to do with the turnsignals or the brake lights. The running lights are powered off of the Headlight switch. Original factory installation is that the headlight circuit and running lights included are not fused. But maybe you or someone else has installed an inline fuse for the running lights. they would still be powered off of the headlight switch so look for a fuse. well in spite of all this, I haven't given much thought to the blalast circuitry in the Moss LED circuits. If nothing else, remove all that stuff and go back to the stock arrangement and see if everything works. Good Luck.
roscoe
If everything was working well you probably have a bad connection or two, either associated with the work you did or it just coincidentally popped up. I'd start with the harness connections where they exit the steering column and tie in to the rest of the system. Make sure all of those pesky bullet connectors are seated firmly and clean. Then check those on the flasher relay and the lights that aren't working. I don't know how many times in my life, working on cars, helicopters and airplanes I have seen a wire connector reconnected, test properly and then fail shortly thereafter. Sometimes a wire holds up just long enough to fool you. When you go back to look at what you did give each wire a gently tug, if you have one that pulls free of it's terminal.....
Jack T
To troubleshoot the problem, first reverse everything you've changed to get back to zero. Take the resistors out of the circuits and install the old bulbs. If your signals operate properly then you can reinstall the LEDs and resistors one by one to track the problem. If they don't work, you can find the problem in the basic system. You say your flasher unit is brand new, but it isn't. It's a couple weeks old now after operating in a non-original environment.
Joe A
Agree with Bob above. If you should purchase the crimp tool and the "push together" tool, you will be amazed at how pleasurable it is to work with the typical British wire connectors.
I also use Deoxit from Caig. One form or another of this product has been around for many years, and was used by the U.S. military under the original Cramolin name:
https://store.caig.com/s.nl/sc.2/category.188/.f
John Turney
Sounds like the flasher relay (not the big one with the eight connections, but the small one with three connections) isn't working. Those three connections are one for power in, one to the indicator light and one to the turn signals. Seems like it is stuck on the indicator light.
Martinld123
Martinld123
Bronze
You were right. I gave it a couple of taps with a screwdriver handle and got it working again. It came from a Moss Motors reseller in California so hopefully I can get a replacement. It is a three connection type that I have found in automotive stores but they maybe electronic but not sure. Thanks again, Marty
Martinld123
Martinld123
Bronze
You were right about the flasher not being new now after a week of being in car. I gave it a couple of taps with a screwdriver handle and got it working again. It came from a Moss Motors reseller in California so hopefully I can get a replacement. It is a three connection type that I have found in automotive stores but they maybe electronic but not sure. Thanks again, Marty
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
G MGB Turn signal, reverse and brake lights MG 9
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
B oh curmbs! turn signals and brake lights were... MG 14
stretchit2 Turn Signals , Brake Lights, Off Switch - Yikes Austin Healey 1
longbridgehealey No brake lights and car won't turn off?? Austin Healey 20
TimK Brake lights/turn signals/DB10 Relay issues Austin Healey 5
C Wedge TR 8 Turn signals and brake lights. Triumph 12
A 100-6 Brake Lights Austin Healey 2
D Brake Lights Austin Healey 7
JFS Wedge Brake and Tail lights Triumph 3
P LED Brake Lights Austin Healey 2
O Brake Lights Inoperative Austin Healey 11
K TR2/3/3A Blinking the Brake lights? Triumph 5
R Brake Lights Austin Healey 23
R No brake lights! Spridgets 2
Wana Brake lights on all the time Austin Healey 41
HighAltitudeTR3 TR2/3/3A Brake lights at night? Triumph 3
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
S Look Ma! No Brake [lights] Spridgets 13
KVH TR4/4A No Brake Lights Triumph 11
5 No brake lights Austin Healey 4
S No Brake Lights Austin Healey 5
drooartz Brake lights always on Spridgets 21
R Brake lights won't shut off Triumph 8
V TR2/3/3A TR-3 Brake Lights Inop Triumph 2
D Brake lights stopped working Austin Healey 40
R Bugeye Brake Lights Spridgets 2
G MGB '71 MGB brake lights MG 18
C Everything was goin good... now no brake lights Spridgets 8
F No Brake Lights MG 5
Mio Brake lights - daytime only Spridgets 2
Stewart Brake lights stuck on MG 2
P TR2/3/3A TR3 Brake Lights Triumph 11
Raymond Dim tail/ Brake Lights MG 32
P extra brake lights Triumph 10
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
R Brake & Tail Lights NONE! Austin Healey 3
I TR6 TR6 brake lights Triumph 10
I TR6 brake lights TR6 Triumph 8
KLUTZ Brake lights always on MG 7
W indicators and brake lights not working Triumph 9
S Flunked Inspection- No brake lights on 79 B MG 6
G brake lights & reverse dont work.. MG 1
W Brake lights stay lit! MG 13
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
