Bolts on straight vs tapered steering coupling
tdskip
Hi guys - so despite being a later TR4A the flexible steering coupling (#32) she had on her TR4A had straight bolt holds whereas the coupling I received from Moss had tapered bolt holes.
She has straight bolts (#30) currently. Do I need to track down some tapered bolts to match the later coupling? Do I need to track down a different coupling?
I did a test fit and the bolts do snug up and the assembly is solid, but not sure if that will have accelerated wear etc due to the above.
What do you think guys?
Platinum
I'd say if the threads are the same, get tapered bolts or a coupling to use the bolts you have. Don't "mix" the wrong fasteners/couplers (not that you *could* get the tapered bolts to go thru the straight coupling).
It may be fine as-is for a bit, but taking the chance it won't loosen up from vibration or a sudden shock from a pothole or other unseen hazardous thingie is in the category: "Not worth th' risk", IMO.
T
tdskip
Agreed Doc. I need to get her back as a rolling/steering car so the rebuilt engine (yeh!) and rebuilt overdrive (yeh!) can go in. But won't drive her until I get this sorted.
It looks like Moss only has the straight bolts. Anyone know differently or if TRF has better ones?
Thanks!
TR4nut
Tom-
I thought all the flexible couplers now are the countersunk kind - is that what you mean by tapered? I didn't think you need to use any special shouldered bolt for them, but I might be wrong.
Randy
T
tdskip
Here are pictures to help, I've not been very articulate;
Coupling that was on the car;
Coupling from one of the Big Three;
See the offset on the new one?
DNK
That's so a screw like this will fit right in
TR3driver
Great Pumpkin - R.I.P
My local Home Depot (OSH, Ace, etc.) has a modest collection of socket head cap screws (like Don's photo). Might be easier to just pick some up than worry over whether a hex head will work OK. (But I think it will.)
Platinum
"Allen head cap screw"... NOW I'm gettin' deja-vu. Get some ~shouldered~ ones of proper length, at least half the length of the bolt should be without thread, better 3/4. I thought TRF had 'em.
Pardon the poor graphic, done by hand... you can find shouldered cap screws at any good "house-o-threads". Match diameter and pitch, shoulder depth. You can cut off excess threads (hacksaw) and chamfer the ends at a 30° bevel with a file.
<span style="font-style: italic">
EDIT: You guys came in while I wuz playin' "Pictionary"</span>. :jester:
DNK
OK What the heck are you talking about doc
This is a shouldered bolt
That what you meant?
Cause I don't think that will fit
Platinum
Nononononnooo.... just unthreaded. Also termed "shouldered". A bolt can have any diameter shoulder.
...now I gotta go wrest th' camera outta Horsemit's ummm... mits?!? I may not be back...
:jester:
HerronScott
Don't you want to use the original bolts (either the TR4A or the TR6 Allen head bolts) as they have holes in them for safety wires? I'm pretty sure that I just used the original TR4A bolts as this looks familiar but I'll check when I can get over to the car tomorrow.
Note that I did convert the lower joint to a TR6 metal coupling (and I believe that I had to replace the lower section of the column as the length is slightly different due to the different coupling).
Scott
DNK
So what he needs is this
Which is what I said he needed in the first place :laugh:
Can't remember what size it is so I guessed 3/8's
TR3driver
I 'grees with Doc's point, but not his terminology. I think he means "shank" instead of "shoulder". Just like his diagram above shows, you should choose a bolt that has an unthreaded shank.
At least the way I was taught, "shoulder bolt" implies that the unthreaded portion is a larger diameter than the nominal diameter of the threaded portion, as shown in Don's diagram. Typically a shoulder bolt would only be used in cases where you don't want the head of the bolt to clamp tightly, like a pivot point. That is clearly not the case here.
Platinum
Your first suggestion showed threads all the way to the cap, that would tend to allow movement under the typical side loads that particular fastener is under. I thought it should be suggested that a shouldered bolt be used instead, to eliminate the possibility... we've seen bolts with full threads used in similarly inappropriate applications WEAR THE SNOT outta the piece they were wound into over time.
Glad we sorted that out.
Platinum
We can argie tensile load vs. side load (of fasteners) 'till the cows knock onna front door, y'know. :smirk: :jester:
M_Pied_Lourd
pics of mine as I disassembled it Skip
and re-assembled
Cheers,
Dave
Platinum
Got any pix of the bolts themselves, Dave?
HerronScott
Oh wait, not all the holes are recessed so can't you just rotate it so the recessed holes are against the threaded adapters and the original bolt heads are on non-recessed holes?
Scott
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
shadowfever Midget seat nuts and bolts Spridgets 2
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
D ARP big end bolts. Spridgets 7
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
G HD8 Carb Banjo Bolts Austin Healey 2
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
M Tranny Mount Bolts Spridgets 3
M TR2/3/3A oil pan bolts Triumph 16
AUSMHLY BJ8 Dowel Bolts Austin Healey 35
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
B McMaster Carr for bolts and fasteners Spridgets 8
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
charlie74 TR6 Bearing cap bolts Triumph 8
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
P Help with torquing bolts Restoration & Tools 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S TR2/3/3A Body Mounting Bolts. Triumph 14
B MGA Mystery bolts MG 2
B TR4/4A Self locking bolts question Triumph 13
J Thread Locker on Shock Bolts? Austin Healey 19
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
F TR2/3/3A Trunnion bolts Triumph 11
S TR2/3/3A banjo bolts to seal up on the early SUs Triumph 4
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
I TR6 Source for Elevator Bolts? Triumph 16
K TR2/3/3A Brake caliper hold bolts? Triumph 1
C MGB Starter bolts MG 5
R Upgraded rod bolts for stock rods Austin Healey 1
R TR2/3/3A 1961 TR3A's Nuts, Bolts and Screws Triumph 5
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
Rut Grade 9 bolts Spridgets 6
Rut MGB Grade 9 bolts MG 4
Rut TR4/4A Grade 9 bolts Triumph 6
wangdango 3000 valve cover bolts/chrome/ss? Austin Healey 4
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber Bolts and Washers for 1/4 Elliptics Spridgets 2
T Spitfire Caliper bolts, again Triumph 2
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
K TR2/3/3A Another windshield question...bolts and screws? Triumph 15
R Fender bolts Austin Healey 10
R Transmission pilot bolts Austin Healey 4
rjc157 TR6 tr6 sheared bolts Triumph 6
