So after 1-1/2 years I'm finally ready to begin restoration of the body. Thanks to all of you (especially Randall and John) who have provided invaluable feedback as I rebuilt the engine, transmission, suspension, and gearbox. It's been a lot of fun, and I've really enjoyed the process. The engine runs great, by the way!
This is my first body restoration, so I would like to get some feedback on the proper steps and sequence. The tub is in one piece and has never been separated. If I remember correctly, the doors and other panels seemed to fit just fine prior to body removal from the frame about 15 years ago. I should also mention this car was originally purchased by my father in 1960, so the history is fairly well known.
My initial evaluation of the tub indicates that the outer and inner sills will need to be replaced because they are rusted through at the B-post, with significant pitting at the A-post. Also, the lower couple of inches on the outer 1/4 panels and wheel arches are rusted through where they meet the end of the inner sill. The driver side bulkhead and floor pans do show significant surface rust in places, but overall seem very sturdy. I was not able to punch through anywhere on them, so I'm thinking there is probably good metal under the rust. Everything else seems in good shape with only surface rust, and a few minor things that need patching.
I would appreciate any advice on the following draft plan for body tub restoration/inner sill replacement:
Here are a few pictures to get a better idea of what's in front of me:
- Door restoration - originals are in good shape except for some surface rust on the bottom. Will blast, paint, and re-use.
- Secure body to frame with service manual recommended padding between body and frame.
- Install doors, then add/remove padding under front and back sill brackets until proper door gap is established, then remove doors.
- Secure the body front-to-back by mounting steel tubing from each A-post to B-post. Then join left and right tubing, also tying into the prop shaft tunnel. This should hold the body halves in the proper position for sill replacement.
- Remove outer sill by drilling out spot welds and cutting corner welds.
- Remove floor pan by drilling out spot welds and cutting corner welds (do I have to remove to replace inner sill?)
- Drill out spot welds connecting bulkhead end panel and inner sill, and also separate outer 1/4 panel and wheel arch from inner sill.
- Remove inner sill.
- Replace rusted out lower couple inches on outer 1/4 panel and wheel arch by welding in patch sheet metal.
- Insert new inner sill purchased from TRF.
- Clamp or tack weld inner sill to outer 1/4 panel and wheel arch, as well as bulkhead end panel.
- Refit door and verify gaps are still correct.
- Weld inner sill to outer 1/4 panel, wheel arch, and bulkhead end panel.
- Install floor pan and weld (re-use old pan if possible).
- Install outer sill and weld.
- Repeat steps 5-15 on other side of car.
- Other minor work (cage nuts, battery box, small holes, etc.).
- Blast tub and prime.
