BN4 Front Wings on a BN1
BoyRacer
Can you put BN4 fenders on a BN1? What is the difference?
I have seen pictures of 100s with 100-6/3000 front fenders. They are the same size and overall shape. I believe you would want a pre-roll up window fender. As I understand it, there were changes to the a-pillar and, therefore, the rear fender mounting flange to the a-pillar, in those later cars. One would also need to create a small recess in the six cylinder fender to accommodate the forward "foot" for the windshield.
I have also measured my 100 and fender length is also ~63"
For all who wonder where the extra two inches went when the wheelbase was lengthened, it's in the interior. The doors are two inches longer in the 100-6/3000 than in the 100.
Today I tried to fit a BN1 fender on a BN6 (same as a BN4, BN7 and BT7). The length and curvature of the fender is spot on. However, the rear edge of the fender has a different configuration and the mounting flange is about one inch short of contact with the hinge pillar face.
So, I guess I answered my own question.
Richard, post a picture of the differences. I'm curious to see if BN2 is the same as well as a early 6 cylinder fender that I have buried in my garage.
EDIT: Just did some checking. There was a change of some sort to the hinge pillar @ body 5001 according parts listing on Moss
Just saw these pics show up on Facebook this evening. Car is for sale in Norway.
I don't know what difference there is between BN2 and BN4 front fenders, but I know that BN1 fenders are quite different in the hinge pillar area. I hung a BN1 fender on a 6 cylinder chassis and the mounting flange to hinge pillar is about one inch short of mating up. Also, the configuration of the rear edge of the fenders are very different.
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
richberman Pictures of BN4 front shroud/chassis joint Austin Healey 5
M BN4 prob with disc brake conversion[front] Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 8
A 100/6 BN4 Door Lock Austin Healey 15
zoohow BN4 Top Frame Installation Austin Healey 1
W BN4 Engine Mounts Austin Healey 2
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
P BN4 Generator Woes Austin Healey 7
W BN4 History Search Austin Healey 7
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
W BN4 Steering box bushing. Austin Healey 2
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
C 100/6 BN4 Soft Top Frame Austin Healey 16
A BN4 Hard Top Austin Healey 23
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
B Side window question for early Longbridge BN4 Austin Healey 4
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
B Longbridge BN4 top frame question Austin Healey 6
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
longbridgehealey Removing BN4 Bonnet Austin Healey 9
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Csarneson Early BN4 steering box pitting Austin Healey 16
Csarneson BN4 Cam Gear Install Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
K Correct side screen nut for early 58 BN4 Austin Healey 14
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
P BN4 Hesitates on Starting Austin Healey 12
Csarneson BN4 Wiring Questions Austin Healey 5
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Bugeyze BN4 Windscreen Shims? Austin Healey 13
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
L 100/6 BN4 Brake fluid Austin Healey 17
L 100/6 BN4 Hood fittings Austin Healey 5
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
L 100/6 BN4 Fuel Tank feed Austin Healey 5
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
