BN1 5 stud conversion
Very nice looking workmanship!new invisible pads? Looks like BJ8 parts? Copper hard brake lines?Sure updates that old BN1 system! cheers Genos2
Genos2 said:
new invisible pads?
Transparent aluminum. Now science fact, not fiction.
Hello OZ BN1, Looks like nice work.
You are going to love the discs on the BN1.
I see you don't currently have the dust shields attached to the brake assembly. Does this mean you aren't going to use them?.
I did this when I fitted MGB discs to my BN1 thinking it would allow more air in. It probably did allow more air in but it also allowed the dust and everything else in and consequently wore out both inner pads in a very short time.
The outer pads had worn very little by then.
After installing the dust shields the new pads lasted quite a long time.
I don't know what the DW setup has for balancing front-rear.
On mine, to get the balance between front and rear brakes I first tried a brake compensator off the rear of a mini but I have doubts whether it worked or not.
I then started by reducing the length of the material on the rear brake shoes. The first time I removed about 25mm from each end of the shoe material for all 4 shoes. After this I removed more material until the rear brakes wouldn't lock on. Sorry but I don't remember exactly how much I removed as this was some 35 years ago.
(Before installing the discs I had just rebuilt the rear brakes and had new linings bonded on the full length of the shoes so there was plenty to play with when it came to cutting it off.)
Not long after I converted to rear discs but that is another story.
Hope this helps,
Best Regards,
bundyrum.
Hello OZ BN1. Forgot to add this bit
GregW, I like that.
Michael Oritt,
One cannot compare what was there before because the shock mounting on the original 4 stud rear end is different to the 5 stud rear end.
Also the Panhard Rod only has one setting and that's not very good even on the best of days.
Regards,
bundyrum.
Hi
Dust shields did not come with the kit, i have read a few comments about the lack of dust shields. I will see how things go.
I have also allowed for a brake booster PBR VH44 or 45 but not planning to install it until I know if I need it. From what I have read it may not be necessary.
Cheers Graham
Hello OZ BN1,
Try The Healey Factory. They may have some or even let you borrow a pair to have some made up. Might be worth a try.
I never used a booster on my BN1.
Regards,
bundyrum.
