General TR Block Crack Repair
Hi Guys,
Pictures of my problem crack.
John thanks for support and advise.
attachment.php
attachment.php
Now, on to the fix. You will need a drill press of some kind to insure you drill the hole perfectly aligned. The block goes on top, and I used a "sticky" tape to keep it from shifting once it was aligned.
If you use a drill press to make a hole, it is only logical to use the same press to start the tap. It is the best way to make sure the alignment is perfect. They provide tapping fluid that really works well, and I finished by hand.
John, Since you seem to like things like this you might like to know what that dimple on the tap is for. It is for a center taper to use as a guide. T-handles for taps also have them. To use it have the work piece clamped in place and then drill the hole or if it is an existing hole use the center taper to align the drill head to the hole. Then with just enough pressure to follow the tap use a tap handle or wrench to turn the tap. This can also be used with reamers.
They are called "Buttress Threads"
I know from the PO that the engine was rebuilt, and I have little doubt that a crack like this is the result of lifting the block using the studs without the head to align them. I may be wrong, but that seems the only explanation.
Very interesting post, but a block can be so weak that lifting from a stud can crack it? I have my engine apart on a stand and want to lift it off and put it on a table. I planned to use a chain on the studs. That's really a danger?
This is one of the best documented repair procedures I've read here.
I'm very interested in how the engine holds up after the repair. Please keep us updated after it's assembled and back on the road.
Thanks.
Tom
Tom...I can see 2 cracks on your block, one downward and the other right in the pics. No matter, the insert should be perfect for it.
Tom 2...that's interesting. Now I'm going to have to find a center taper to add to my tool collection!
KHV...I don't think we have definitive proof, but the general consensus is that lifting with the studs puts a lot of leverage on the end studs, and there is not much meat there to take it. My TR3 engine had never been rebuilt, and the stud threads were fine. This TR2 engine had been rebuilt by the PO, and it had the crack. It's very tempting to lift by the studs, as they are convenient...but it could cause the cracks.
Tom 3...the motor is back together, but it'll be at least a year before it gets tested...stay tuned!
A question for John and others about lifting a TR3 / TR4 engine and transmission.
Do you think it is safe to lift a fully dressed engine and overdrive transmission using the head studs with the head fully torqued down and the chain sling fastened to two of the studs?
I guess its a moot point as that is how I lifted the engine and trans out of my TR4, but would like opinions anyway.
Thanks!
Matt
Thanks.
Tom
Agreed, And, I hope I never have to use it!!
After a long research and preparation I finally started block crack repair.
Thanks to the magnetic base drill I was able to put insert in a problem stud hole without taking engine out. Positioning the drill and figuring out the countersink depth was the hardest part.
Now the only problem I have is how to file insert to be flat with the block without scratching the surface around it. I only need to file about .003-.004”. Any ideas anyone???
Below is couple of pictures taken thru the process.
Template to see if magnetic drill will work (not to much space, studs removed on one side, lower studs holding the liners so electromagnet don't pull it
attachment.php
Insert and drill marked for depth
attachment.php
Using the stud as guide for position.
attachment.php
Drilling
attachment.php
Hole with countersink
attachment.php
The way leveling was done
attachment.php
Using the drill to start the tap
attachment.php
Threading
attachment.php
Insert installed with install tool on it
attachment.php
Jig to drill the locking pin hole
attachment.php
attachment.php
attachment.php
attachment.php
Drilling
attachment.php
attachment.php
attachment.php
attachment.php
Threading
attachment.php
attachment.php
attachment.php
I like that magnetic drill!
A decent flat file will lower the top of the insert. I started using tape to keep from scratching the surrounding deck, but after a few minutes you get the feel of the file, so the tape isn't necessary. I changed the angle frequently...but that may be hard for you with the engine in the car.
Hi,
Please tel me if this is a mistake of previous owner, two thinks are wrong:
[FONT=Times New Roman, serif]1.fan pulley timing mark is not opposite (180 degree) the crankshaft key
2. the chain gears are not lining up perfectly
See the pictures
attachment.php
attachment.php
attachment.php
[/FONT]
Hey Tom.
It does look like the PO missed the marks by one link. An advanced cam would move the torque band lower, but reduce high end torque.
I'm confused about the pulley mark. In the picture have you checked the piston for exact TDC?
The pulley is definitely assembled wrong. Timing chain sure looks suspicious, but I would check actual valve timing before changing it. It is possible that the gear is marked wrong.
Thank you.... problem that could have ended badly went very well indeed.
Thanks for all the pics.
that is fascinating, especially as I seem to have the same problem. Would you consider selling or renting out the kit so as to share the cost? I know it is pricey.
Buttress threads are actually quite common for vices used on drill press and mill tables and other uses in a machine shop. They are good because the pressure from the threads does not spread the part and cause cracks.
I also noticed in the pics of the tap that it was being turned with wrenches but not supported with a center point to keep it true to the drilled hole.
Yeah, but that "stitch" insert does not have buttress threads. With buttress threads, the load bearing surface is perpendicular to the axis, while the stitching threads have it actually slope the other way. That's what causes the insert to actually grab the sides of the hole and pull them inward; while a buttress thread just doesn't push them outwards.
Very hard to see in the insert photos, but you can see it in the bottom row of threads on the tap photo that John posted (repeated here)
Here's a drawing of a buttress thread for comparison
Just a follow-up.
The engine is running, and no more sign of any leakage at all. The insert appears to be doing it's job very well! Since the original post 2 more owners "rented" the kit and saved a couple more old blocks. I am down to only a single insert left...which made the investment less formidable for all that needed it!
I'll post again when/if the final insert gets mailed out to save one last block. Whoever gets it this time gets to keep the kit!
