BJ8 Top Frame Bumpers
JamesD
When the rag top is raised on the Mk 3 Healey, the top frame sits on a pair of rubber bumpers, 1 on each side, just behind the seats. I have not seen these for sale anywhere, nor are they mentioned in the BMC parts manual. I will try to make a pair of them out of "wheel arch buffers". Before doing that, I was wondering if anyone has any experience with them.
That does not ring a bell with me hope others can help U.
It seems that a photo might help. In this image, the driver's door is the bottom left, and the left rear fender is the bottom right. The odd-shaped shiny thing in the middle of the photo holds the piece of rubber in question. There is a split rivet through the middle of it, and underneath is all that remains of the rubber bumper, which once existed on the top side as well. The bracket is attached to the chrome piece in the lower right by 2 small screws. The exact thing, in mirror image, exists on the other side of the car. I should add that this is a 1967 model, and this part might or might not exist on older BJ8s.
OK Go to the next post " The Man in command " then select MEDIA there will come up a set of pictures of a BJ8 bare top frame on a red BJ8 U will see them there.
Hello James. Those are Shut Pillar Seals. As a unit (aluminum arm, rubber buffer and rivet) Moss sells #803-875. Two photos attached from Moss site.
The rubber buffer is the same as used on the front rain rails, Moss #031-359 about $1 and as you pointed out, the wheel arc buffers.
I used these and cut them to custom fit.
I used a rivet with a washer being I have rivets, vs using the split type washer which is correct.
I believe the purpose of that rubber buffer is to make a seal. You may find bending the arm to position it for best fit maybe helpful.
Resurrecting.
Anyone got a shot of how these are affixed to the car? A couple screws, obviously, but to which part of the body (shutpillar, hood enclosure, etc.)? Sheet metal screws, machine screws, bolts?
Anybody know if these are OEM? My car was pretty much stock, except for a couple paint jobs, when I bought it at 64K miles and I don't recall ever having these (haven't had a chance to check for screw holes yet).
My early 65 does not have these and there are no holes for mounting the screws. The car has been in My family since 1970 and I am the only one to have had any cosmetic work done to the car so it's likely that they were never there. Of course it's British soooo...
I've been looking into this, off and on, trying to decide if I want to add another task to my list. I finally checked my copy of Anderson&Moment's book and, sure enough, there are a couple photos that show these on a, presumably, totally original, or faithfully restored car. However, like 'bdcvg,' my car doesn't have them, and there are no holes for fitting them. My car has been repainted a couple times, but AFAIK nothing was done to the interior. So, this appears to be a case of: a) the factory quit fitting them as a speed of assembly/cost issue (my car is a BJ8 P2 built in Nov. of 1966), or b) sometimes they got fitted, sometimes not.
Also, the A&M's photos show a rather thin, sheet metal bracket like 'JamesD's,' whereas 'AUSMHLY's' is made of thicker metal (aluminum?). So, I'd like to have these, but then my car wouldn't be 'original.' What to do?
