For Sale BJ8 and BT7 parts for sale
Do u have any door controllers for a BT7, drivers side
By door controllers do you mean the latch assembly that fits into the back edge of the door ?
Hello, would you still have the adjustable steering wheel and Wing Flashes?
Yes , still have them contact me by email and I can send you some pics .
my email address is g_house8008@charter.net. I guess I am not smart enough to figure out how to find your email...
I don’t have those , find a rechrome shop they can fix the pitting rust etc .
mine are at the rechromers right now for my BT7
Bummer! My quest continues then in search of a decent used set. I've already talked to a couple local shops that deal with re-surfacing and re-chroming vintage car parts, and who were familiar with dealing with stuff from Moss. They all wanted more to fix these (image below) than it costs to buy repro parts from Moss ($1600).
That maybe true as far as cost but the quality of the repro parts from the usual suspects is sometimes questionable .
I would bite the bullet and restore original parts before buying questionable repro any day of the week . At least you know they will fit and the quality of the chrome will be way better than the Far East chrome job .
Closing in on the finish line of my 3rd and last Healey restoration . Need to find good homes for all this stuff .
Dont let it go to waste , need to keep these historic cars running .
Lots of leftover parts from BJ8 and BT7 Tri Carb restorations .
PM me for costs and shipping info . I can take most items to Ogdensberg UPS store to reduce shipping costs now the border has reopened .
Make me sensible offers on all items I'm not looking for huge $$$ just want help enthusiasts keep them on the road , I also have some stuff not listed . Just ask I may have what you need .
Let keep these old girls on the road .
1- complete BT7 seat back and frame assembly . Needs recovering but good frame etc .
1- generator with pulley and coil mounting .
1 pair rear seat cover , barely used (AMBLA) as original .
1-original NOT REPAIRED generator mounting plate off the side of the engine .
1- BT7 clutch pressure plate
1-rear engine plate
2- full sets original pistons standard size very useable condition .
1- set original Con Rods
4- Bumpers , 3 original , 1 repro .originals for rechrome repro driver quality.
2-BJ8 fuel filler necks and caps
1- 4 blade alloy fan rare part
2- oil filter assemblies with 90 degree adaptor piece
3-oil pumps
1 pair original rear seat pans , minor weld repairs needed .
1-pair Girling brake servo brackets
4-original air filters BJ8 2 pairs
1-set 2 wing knock offs , coarse thread
1-stub axle right side /hub extension , good splines coarse thread .
1-pair chrome corner pieces originals good rechrome candidates
1- pair wing flashes originals
4-chrome BJ8 door waist moldings originals , good rechrome candidates
1-BT7 flywheel with starter ring
1-BT7 Harmonic balancer ,for core or rebuild .
1-pair BJ8 foam door caps
1-distributor drive gear
1-oil pump drive gear
1-BT7 crankshaft for regrind
1-timing cover
1-original spare wire wheel original paint in good condition with bias ply tire ,perfect for concourse
1- set driver quality knock offs two ear type coarse thread .
3- sets original valve cover cap nuts
1-set timing gears useable
8-brand new left and right moulded end cap rubbers for soft top surround seals
1pair new radius arm bushings
1- original fuel pump with BT7 mount plate (non electronic) in good rebuildable condition
1- original panhard rod for BT7 , sandblasted primed and painted plus new bushings and bracket etc .
misc internal engine parts , main caps , timing chain adjusters etc .
other ods n ends not listed …..just ask me I may have what you need .
Do you have a pulley for a bj7 or earley bj8 ?
Generator , water pump, crankshaft ????
Do you have a pulley and damper 1/2”
I have a crank damper that came off a BT7 but it’s separated from the damper rubber so would need to be redone by someone like damper doctor.
Rummaging around looking for something else . Came across this , 3/8” crank pulley , would be off a BT7 .
Not sure if that’s what you’re looking for .
So just so I understand you want a bonnet (hood) or a softop hood ?
Ok , I don’t have a hood but I do know a guy close to me that has one or possibly two .
You do realize I’m in Canada so shipping for an object that large will not be cheap .
I will contact him and see if he wants to sell them .
One of them is louvered I think .
