BJ8 and BT7 parts for sale
Healey Nut
Lots of leftover parts from BJ8 and BT7 Tri Carb restorations .
PM me for costs and shipping info . I can take most items to Ogdensberg UPS store to reduce shipping costs .
CANT DO THIS UNTIL THE BORDER OPENS AGAIN .
Make me sensible offers on all items I'm not looking for huge $$$ just want help enthusiasts keep them on the road , I also have some stuff not listed . Just ask I may have what you need .
Let keep these old girls on the road .
2- original starters
1- BT7 clutch pressure plate
1-rear engine plate
2- full sets original pistons standard size
1- set Con Rods
4- Bumpers , 3 original , 1 repro .originals for rechrome repro driver quality.
2-BJ8 fuel filler necks and caps
1- 4 blade alloy fan
2- oil filter assemblies
3-oil pumps
1-pair Girling brake servo brackets
4-original air filters
1-set 2 wing knock offs , coarse thread
1-stub axle right side /hub extension , good splines coarse thread .
1-pair chrome corner pieces originals good rechrome candidates
1- pair wing flashes originals
4-chrome BJ8 door waist moldings originals , good rechrome candidates
1-BT7 flywheel with starter ring
1-BT7 Harmonic balancer ,for core or rebuild .
1-pair BJ8 foam door caps
1-distributor drive gear
1-oil pump drive gear
1-BT7 crankshaft for regrind
1-timing cover
1-original spare wire wheel original paint in good condition with bias ply tire ,perfect for concourse
1-Full set (4) bumper overriders good driver quality
3- sets original valve cover cap nuts
1-set timing gears useable
8-brand new left and right moulded end cap rubbers for soft top surround seals
1pair new radius arm bushings
1- original fuel pump (non electronic) in good rebuildable condition
misc internal engine parts , main caps , timing chain adjusters etc .
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
With the sale of both my BJ8s Im open to offers on all the BJ8 parts . Just looking to help keep these old girls running .
Healey Nut
Healey Nut
NO slide bolts available. Sorry .
Healey Nut
Healey Nut
Sorry that’s long gone , I used it to repair my boot lid for my TriCarb project . Made one good one out of two and scrapped the rest .
jlburdge
I didn't think it would be around. I just thought I could replace one that had lots of runs on it, though can be fixed no problem. ldb
AN6-TX
Any chance you have a tach for a BJ8?
Healey Nut
Healey Nut
Nope sorry , no Tach spare . All the instruments I have are gold face ones .
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 14
BJ8Healeys Bt7 ---> bj8? Austin Healey 15
D Differences between BT7 and BJ8 engines. Austin Healey 12
6 Dash Instrument Conversion: BJ8 > BT7 Austin Healey 3
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
J BJ8 versus BT7 Shroud Austin Healey 11
JamesD BJ8 Top Frame Bumpers Austin Healey 6
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
R Distributor: Reassembling BJ8 Engine Austin Healey 5
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R New Engine mountings BJ8 Austin Healey 1
T BJ8 carpet Austin Healey 2
R Cylinder head gasket BJ8 Austin Healey 32
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
BJ8Healeys For Sale 1965 BJ8 for sale Austin Healey Classifieds 0
M Getting behind the dash on BJ8 Austin Healey 4
J BJ8 flywheel take some pounds off Austin Healey 17
Keoke 1966 AH BJ8 on eBay Austin Healey 18
L BJ8 Batteries Austin Healey 8
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
B BJ8 door hinges Austin Healey 7
BJ8Healeys For Sale BJ8 engine for sale Austin Healey Classifieds 0
B Wanted BJ8 door hinges Austin Healey Classifieds 0
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
HealeyPassion FYI - AH BJ8 super car for sale Austin Healey 3
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
M 1966 BJ8 Top Austin Healey 1
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
T BJ8 Carpet Padding Austin Healey 4
S BJ8 Rear Seat Side Panels Austin Healey 3
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
