Healey Nut
******BEEN CLEANING UP MY SHOP DOING INVENTORY MANY NEW PARTS ADDED , LIST IS GETTING SHORTER , SEE BELOW .****
Please note ***********
If you are inquiring about parts and want a shipping cost I need a FULL mailing address inc post/ZIP code to get a UPS quote and a current active email address if you want any pics of the items .
Tks .
I have added AH spares part numbers to a lot of this stuff for reference as we all have different terminology for parts .
Lots of leftover parts from BJ8 and BT7 Tri Carb restorations .Need to unload some of this stuff to some needy owners . Offers welcome on anything .
Three ground up restorations done that’s all for me , this stuff needs to find new homes and be used to keep these old cars going .
PM me for costs and shipping info .
Parts are slowly disappearing to new homes , do t sit on the fence too long or they will be gone !!!!!!
Make me sensible offers on all items I'm not looking for huge $$$ just want help enthusiasts keep them on the road , I also have some stuff not listed . Just ask I may have what you need .I even have some brand new small parts unused as well .
Let keep these old girls on the road
BJ8 Door card clips TRP251 - 12 new
Upper Door hinge BJ8 used
seal clips new 10 DRF236
BRK236 felt washer 8 new
2 wood horizontal section above window for soft top used
1 pair wood seat rail used original SET116
1 battery backer wood used original ELG205
Alternator /dynamo adjustment pillar mount.
1- complete propshaft adjustable type .
1-original non enamel front shroud AH wing badge MK3
1 -set rear axle U bolts , brand new . SUR142
4 - hydraulic hose star lock plates CL4172 Ahead for Healey number
1- bullet mirror MRS108
1- regular wing mirror MRS105
4 short wheel spokes new WHE162
4 long wheel spokes new WHE163
2-twin cable choke firewall bracket CBS126
2- 7” sealed beam units all working LTG172
4- orange indicator lenses LUCAS LTG141
2 clear lenses Lucas LTG122
1- acorn top coil good resistance
1- regular coil good resistance ELI140
Various sizes wire type hose clamps CHT161a style
4- used but good A arm pins and nuts SUF132
2- fulcrum pins and cap nuts SUF108
8 large rubber side light etc body gaskets new LTG143
16 soft foam plastic lens gaskets new LTG146
Large heater hose support clamp flat metal type CHT163
1-thermostat sleeve
1pair bonnet safety latch plates BON141
1 chrome boot strap staple WHE178
1set front shroud grill brackets GRL129
1- complete mechanical tach drive unit .
Trunk prop rod bracket BOT126
1- hood prop rod bracket BON140
1- brand new pair plastic headlight buckets 2 adjuster with retainer ring . LTG182
1-generator with pulley and coil mount bracket
1- perfect condition generator mounting plate . ENG776
1-BT/BJ7 rear upper soft top trim rail .
1- BT7 clutch pressure plate
1-rear engine plate
1- front engine plate
2- full sets original pistons standard size very useable condition .
1- set original Con Rods
2-BJ8 fuel filler tubes
2- oil filter assemblies, with 90 degree adaptor piece.
3-oil pumps
1-pair Girling brake servo bracketsBRK317
1-stub axle right side /hub extension , good splines coarse thread .RAX205
1- pair wing flashes originals
4-chrome BJ8 door waist moldings originals , good rechrome candidates
1-BT7 flywheel with starter ring
1-BT7 Harmonic balancer ,for core or rebuild .
1-oil pump drive gear ENG674
1-BT7 crankshaft for regrind
1-original spare wire wheel original paint in good condition with bias ply tire ,perfect for concourse
2- sets original valve cover cap nuts ENG740 NOT STAINLESS .
1-set timing gears useable
2- brand new rear spring bushings SUR125
1- original fuel pump with BT7 mount plate (non electronic) in good rebuildable condition .Note ***Round body SU***
1- original panhard rod for BT7 , sandblasted primed and painted plus new bushings and bracket etc .
misc internal engine parts ,timing chain adjusters etc .
other ods n ends not listed …..just ask me I may have what you need .
Tks .
1-thermostat sleeve
1-rear engine plate
3-oil pumps
