BJ7/BJ8 Convertible Top
AUSMHLY
Sooner or later, we all need to replace out convertible top material.
In order to get the best fit of the top material, one needs to make sure the convertible frame is in good working condition, that it raises and lowers with out binding, that it lowers into the rear well and that it clamps onto the windscreen securely. Then there's the how well does it fit question when in the up postition. How's the seal around the side windows and the windscreen.
I spent quite a bit of time figuring out how our convertible top frame works on our BJ7/BJ8 cars. I was in need of a new top, and choose to go with a fabric top, but needed to address my top frame fit issues first. If the top frame does not line up with everything, when in the down and up postitions, then it's not ready to install the material.
I've heard that the Healey top frames are a bit more complex than some of the other convertible frames, so I knew I was in for an adventure. I am thankful to all those here who helped me thru this project. It took me a while to back engineer how it works and figure out what needed to be addressed to correct the problems my top was challenging me to fix.
So for those who are in need of replacing their top, or thinking about doing it, I've searched the archives here on the BCF for you, and will provide the links below. Maybe you'll find some advise or answers that may help you out.
I installed a Robbins Sunfast top on my BJ8. I'm pleased with the fit and finish, and that when driving at speed, it's much quieter than the last top I had, because I addressed the convertible frame issues. Wind noise is at a minimum now and it's acually water tight. Really.
Cheers,
Roger
10.20.10 Soft top to window adjustment
> Soft top to window adjustment? <
01.21.11 How low does the convertible top seat
> How low does the convertible top seat <
04.28.11 Window winder mechanism BJ7
> Window winder mechanism BJ7 <
05.09.11 How difficult is it to lower or raise your top
> How difficult is it to lower or raise your top? <
05.16.11 Top Bow
> Top bow <
05.17.11 Does your window rattle when in the down postition
> Does your window rattle when in the down position? <
06.18.11 Hood frame fit
> Hood frame fit <
12.16.11 Bow wood to window gap
> Wood Bow to Window Gap <
AUSMHLY
AUSMHLY
Re: BJ7/BJ8 Convertible top Q&A
Rick,
Sorry, my intentions were not to scare anyone from trying to do the job on their own, rather to offer help in the form of what others have contributed also.
I've gotten a lot of PM's asking for my help, being I spent a lot of time learning about it. So I thought I'd start a post with links that may help others.
How's that saying go...no good deed goes unpunished. :angel:
Cheers,
Roger
Johnny
:yesnod: :yesnod: Really a beautiful job Rick, I'm envious. Maybe now I'll go back and straighten out mine, thanks for all your help with the links.
I do have one question with the sunfast tops. On my BMW Z4 top which is similar, I had to first clean it, then spray a sealer on, actually harder than it sounds. Now the water beads up on the top where as before it didn't. Does water bead up on the sunfast top??
AUSMHLY
AUSMHLY
Hi Johnny, who's this guy Rick?...lol.
My reseach on the web came up with...
A quick word to the wise: If you have the opportunity to protect your convertible top—whether it's vinyl or fabric—do it the very first day you bring it home, before it has a chance to get dirty. Pay special attention to the stitching. Manufacturers use poly-cotton thread—comparatively weak, and always the first thing to go. The stitching needs a UV sealant or protectant, if it's to hold things together for any amount of time.
We have found in our testing RaggTopp is one of the top products on the market. 303 High Tech Fabric Guard is also a quality product. Either will restore the repellence to factory specifications and keep your fabric top looking good. Be sure to apply protectant to a clean, dry top. Never saturate; light, even coats are always best. Reapply monthly to maintain an optimum level of water repellency.
Johnny, I can't say if the water beaded on my top from what Robbins applied. I put two coats of RaggTopp sealer on my top before it left my garage. Maybe because my top is new, I found the process very easy. I used the RaggTopp kit.
1. I washed the fabric with RaggTopp cleaner and a horse hair brush.
2. Rinsed it off well with a garden hose.
3. Dryed it with a waffel weave micro fiber towel, and made sure it was absolutely dry by letting it sit in the sun.
4. Applied a light coat of sealer from the spray can. Let it dry, then I applied another coat.
When I wash the top, the water beads.
Roger, aka Rick :smile:
Johnny
Yes, thanks that's what I used also. Sorry about the name change Roger, frequently I have "senior moments".
Legal Bill
That is the best fit I have ever seen. I can't even see where the two pieces that make up the window frames butt up against each other. Please come to my house immediately and correct my top.
By the way, how easy is it to raise and lower your top?
davidb
Roger
Your itemized search thru the archives was very helpful. As usual the photos tell the story better than words. My BJ8 top doesn't fit as well as it should. But with all the apparent adjustments that are possible, and the patience of a crack addict, it'll take a better detective than me to set things right.
So when you're finished with Legal Bill's top, can you fly up here to fix mine? I'll pick you up at the airport. There'll be beer and women.
Great job on your softop. Your garage is frustratingly neat and tidy.
Cheers
DB
Lotuswins
Roger,
Thanks so much for the references, they are all extremely helpful, but intimidating.....
I just about have the interior done, and tried to fit the top frame, untouched so far by me, to the car. Many issues are apprent right off.
Would you perchance have pictures of the hood frame collapsed in the rear, from the top looking down at the various areas (like where it fits inside the rear trim panel, the rear where it fits inside the curvature of the shroud, and near the seat back edges?
Also, I'm puzzled about where to start on the frame, and since new are not available, and even if they were it would probably require more adjustment than the old, it looks like I'll have to rebush the pivot points. Any tips on doing this little chore? I do have a lathe and can weld so hopefully I can manage most of the work.
I do have one other question that would help, are the short 'S' pieces on the sides of the frame supposed to be flat and straight? Mine seem to have been tweeked a few times and have a shape of their own as well as having worn pin holes.
Thanks for any help,
Lotuswins
Thanks so much Randy, I'm always amazed by the quality of your pictures, and the patience it must take to get such detail. Great work.
I've got the top frame apart now, and I'll be making new pivit pins for 6 of the most worn joints, along with new bronze washers. I'll reassemble after being sand blasted, then have it powder coated. I've stamped numbers on each piece to keep it organized, and your pictures will help on installation and putting on the top.
Car interior is now 99 percent done...can't wait to drive it.....
Leo_Speichinger
I can not access the articles due to it wont accept my password or user name. any ideas on how to access them.
Leo
Lin
Well, I have a BT7 Roadster, but after reading Roger's articles and the Forum posts, I am tempted to go buy a BJ8 just to work on a convertible top! Great job as usual, Roger. You must have the best fitting top in Healeydom - it looks great. What is your next project?
Lin
rogerappleton
hi guys
ive just joined bcf and would like to follow the links given to the tips at the top of this post.
i cant seem to get them to work?
seem to point to an older defunct website??
any help much appreciated as i'm about to try relacing my hood.
regards
roger
HealeyRick
CanberraBJ8
Well, I have done some work on my top and it is much better than before... but not as good as AUSMHLY's.
I shimmed the frame and without the fabric it fit well - this was a result of
-replacing the bolts/pivot pins for some 10mm high tensile bolts which fit much more snugly than the old worn pins...
-shimming the hood frame
-moving both door glasses up as far as they'd go
-removing the door hinge shim on the right door (which allowed the glass further height as well as moving it forward).
-moving the windscreen a little more upright to match the 1/4 light frames.
https://i1349.photobucket.com/albums/p744/356fair/Healey pics/Healey re-trim/null_zpsf980c731.jpg
However, once the fabric was added, the wood trim doesnt align as well under tension. Also There is a bit of wrinkling at the 3/4 corner. Could this be removed? It doesnt seem so from the adjusting I've done. If the fabric is gathered more to the rear to tighten the 3/4 area there is an excess at the rear window...
https://i1349.photobucket.com/albums/p744/356fair/Healey pics/Healey re-trim/null_zpsfb996a2a.jpg
Otherwise the fabric is now drum tight and the windows look like they should seal pretty well. It is pretty tight when clipping the windscreen latches though - I doubt my wife would be able to put the top up alone.
Any thoughts?
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
J BJ7 Mark II with BJ8 Dash Austin Healey 11
B New Window Seal for BJ7/BJ8 Roll Up Windows Austin Healey 1
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
healeydan BJ7/BJ8 Vent Window Corner Block Austin Healey 13
D BJ8 muffler on a BJ7? Austin Healey 6
J Can A BJ7 Two Light Schroud Be Coverted To A Four Light BJ8 Style? Austin Healey 6
60TR3A BJ7/BJ8 Boot Cover Question Austin Healey 15
Brinkerhoff BJ8 & BJ7 barn finds Austin Healey 1
D Installing BJ7 version exhaust system on my BJ8 Austin Healey 3
AUSMHLY Window Regulator BJ7 vs BJ8 Austin Healey 26
F How much of a premium? BJ8 vs. BJ7? Austin Healey 16
B BJ7 / BJ8 drainage channel Austin Healey 13
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
B BJ7 & BJ8 soft top rear seal Austin Healey 2
B BJ7 or BJ8 soft top replacement Austin Healey 7
HealeyPassion BJ7 or BJ8 Nical hardtop ques. Austin Healey 1
Schroeders BJ7 Exhaust on a BJ8: do I need downpipes? Austin Healey 10
chicken Are BJ7 doors the same as BJ8 Austin Healey 8
GregW Measurement for shut pillar top piece BJ7 or BJ8 Austin Healey 6
L BJ8 Cam with BJ7 Engine? Austin Healey 1
David_K Dynaplastics Hardtop Value [BJ7/BJ8] w/Pictures Austin Healey 11
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
J Doors different between a Bj8 and Bj7? Austin Healey 5
J BJ7 vs. BJ8 Austin Healey 8
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
