Best way to improve handling?
Steve P.
Just starting on the restoration/upgrade of a 1973 Midget. The plan is to build it for autocross as well
as a weekend driver. Other than a complete rebuild of the front end and new rear springs
& shocks (I want to stay with lever shocks), what would folks here suggest doing? Starting
with the most bang for the buck.
Things I'm thinking about include reducing unsprung weight by going to mag wheels,
larger sway bar, and lowering the whole car. And how low can you go practically
speaking?
Would appreciate any and all suggestions. TIA
Steve
HealeyRick
If you know where you are going to autox, find out what suspension mods they allow before bumping you up a class.
Most bang for the buck would be to talk to Tom Colby at Speedwell Engineering and get some free advice as to what would make the best integrated system. https://www.speedwellengineering.com/ . I'm guessing the recommendations would be bigger front sway bar, added rear sway bar, lowering springs. Have your shocks rebuilt by Peter C at World Wide Auto Parts with uprated valves https://www.nosimport.com/british-c...rebuilt-better-than-new-world-wide-auto-parts
Tires will probably make the biggest improvement, although I don't know what the hot one is for autox now
upsize to 14" rims to get a better selection of tires (if class rules allow)
If you go with a heavier front bar, I'd fit a panhard on the rear and stiffer springs. NO rear sway bar.
nomad
I'd go with a Watts linkage on the back rather than the Panhard bar that Trevor suggests. I fitted a Panhard bar and it does tend to bind at the suspention limits. Agree that fitting a rear sway bar can work but usually doesn't. Has to be light and just right.
Kurt
Panhard is much cheaper and with lowering and stiff springs the binding is minimal (IMO). I also think I have a panhard laying around here that was removed from my midget when it was returned to "cruiser duty".
nomad
Agree that the Panhard bar is MUCH cheaper but for my spirited street midget I wish I had sprung for the Watts or made one up.
Kurt
SaxMan
I, too, was considering suspension improvements to my Sprite as the major winter project. I'm not looking to do anything crazy, just to make the car a little more fun to throw around. I already have Peter C. lever shocks on all four corners and new tires. I figure replacing the bushings is a good place to start just with the existing setup. It sounds like the rear sway bar is probably not a good idea, but getting a slightly thicker front one may help. Or is this a case of trying to fix something that isn't broken?
Adding a heavier front bar and nothing else may introduce understeer. A thicker sway bar is sometimes needed as suspension travel decreases such as when the car is lowered. Or, a thicker bar may be needed if the spring rates are increased. It gets complicated real quick.
For a 1/2 elliptical rear spring car . I think poly bushes on the rear of the car, a panhard bar, and a 5/8 sway bar on the front may tighten the car without making it plow into corners.
BlueMax
You have many options to change the performance in your cars handling. spring rates, ride heights, camber, anti roll bars, unsprung weight, total weight of car. tires, wheels, brakes, munford link, panhard bar and watts link. All of these are subject to your driving style and what your wanting out of the car. You can find a lot of off the shelf performance or a blend which will require fabrication skills and equipment. Lots of nice stuff out their for these little cars now , but do your homework because not all off the shelf parts are the same quality.
glemon
I had 67 with front and rear bars and I always thought it handled very well, I don't remember the specifications on the bars (if I ever knew them, car came with the bars on) but I am guessing they were a set from ADDCO. Course I was just a kid, but it sure seemed to handle flat a neutral around the corners on the city streets, never autocrossed back then.
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
