TR2/3/3A assembly, TR3A rear fender and radiator stays
Dr_Mike
TS60014
1/. I have two new stays for the rear fender, courtesy of Moss about twenty years ago. They are still listed, but I can find nowhere on the car to attach them and Moss does not seem to know either. Any suggestions?
2/. The radiator stays seem to rest on the horns. I am sure they should not! The rad lines up nicely with the engine, so does this mean I should raise both, or just the radiator. How much space should there be there? or can I just bend the horns down a little?
3/. while I am here... there is no visible attachment for the spring that steadies the hand brake cable: probably rusted off long ago and forgotten! Bolt an eye to the floor near the differential?
Ah, the joys of assembly! Bits now everywhere after another move.
and doing it now in a tent as my rented space was just too expensive. Planning to finish by August.
Dr Mike.
Still owning a Morris minor convertible
Former owner of 1933 Standard ( student days) and 1960 MM Traveller( new)
etc.
Ha!
Frank Canale
Hi Dr. Mike, I think this photo showes the small bracket for the brake cable. The bracket is located on the passenger side at the rear of the prop shaft tunnel, under the passenger floor. The prop shaft tunnel has already been removed in the photo. My frame has tabs welded to it for attaching a flat metal strap between the frame and the bottom of the rear wings. I can get you a photo tomorrow when I get to work and I will post it tomorrow afternoon. I am not sure if that is what you are describing. Frank
Dr_Mike
I confess that I had not looked at the frame for a place to anchor the fender stay so I shall look tomorrow. I had expected it to be on the body.
i will let you know!
Graham H
you can see the two tabs at the rear of my chassis where the rear fender supports are attached.
Graham That photo came out very small and I can't post a larger one sorry
LionelJrudd
You can see the tab on the chassis just in front of the rear spring mount. It is directly opposite the tab on the rear fender, so the brace goes horizontally from the fender to the chassis.
CJD
If your radiator lines up with the engine, then do not adjust the stays to clear the horns. As you suggested, simply bend the horn mountings down slightly until the horns clear the stays. It is normally pretty close...and the horns have to be removed to work on a lot of the parts on the front of the engine bay.
I think Graham and Frank have you covered on the other items...
Frank Canale
Looks like Lionel beat me to it but here is another picture of the tab mounted near the rear spring mount. This is the passenger side.
Dr_Mike
thank you all again. the forum has been very helpful.
the fender tabs are indeed where they are supposed to be, and I shall happily bend the horns down to clear the stays. I suspect the right horn, which is larger, will gave to be notched to clear the radiator. (I recall seeing this in one sitting in my surplus box. and wondered why!)
a little much needed rain today. We have had very little this spring: the garden has become quite an issue even though it looks fabulous!
Dr. Mike
Graham H
I see you have worn the tits off your tyres David but you still have the join mark down the middle, need to do some more TRing.
Graham
DavidApp
You are right there I do need to get some more miles on the clock.
I have done 300 miles so far and still getting comfortable with the entirely different driving experience to modern cars. It has been nearly 50 years since I last drove a TR3 and everything on the road seems to be much bigger these days when you are so low down.
David
Graham H
Hi David, I know what you mean, 50 years ago I would have had my foot flat to the floor blowing on the windscreen to get the last once of speed out of the beast without a care in the world now it's a whole new ball game, you are listening for every new noise and at the back of your mind you wonder if this is safe.
Graham
Dr_Mike
David those are nice photographs! And you add some clues as to how you dealt with the radiator-horn interference
Back to work.
with regard to those big cars on the road that always seem to exceed the speed limit: I decided that the best defence ( after offence) is to have good visibility so I will be adding LED brake lights, LED turn signals, and consider changing the rear turn signals to amber if I can find amber lenses to fit. We live in a backwater with max speed of 50 mph, and mostly less, but those big black pickups apparently do not read.
Thank you all
CJD
Interesting...David, you had to bend your strut to clear the horns. I’ve never had to do that. My support rods are perfectly straight:
Well...never mind! I just reviewed views of my 1960, and it did, indeed, have bent rods. So Mike, I stand corrected...the later cars used bent support rods, but I do not know when the change happened.
Dr_Mike
John; there sees to have been a change in the mounting of the horns. Yours angle much further inward than David's ( and mine). the radiator stay goes almost over the top ( North Pole) of David's and my horns. Car #TS 60014 if we believe the attached plate, and I found the body numbers too after 20 years MIA. Just another British diversion to keep us on our toes?
I will try for a pic in the morning
Mike
martx-5
... So Mike, I stand corrected...the later cars used bent support rods, but I do not know when the change happened.
My car has the bent rods and is TS23677. A likely change was at TS22014...Introduction of the TR3A.
Dr_Mike
attached Pics from TS60014: horn mounting quite different from John's, and the stay rests in a slot so that it can easily be got out of the way, unlike John's which goes through a hole in the bracket.
Vive la difference! or "Every man for himself" ( Women and children first")
As an ex Brit (1960) I can happily say "Bloody British" and muddle on.
The third pic is a reinforced hole on the front of the inner fender: The only use for this seems to be to attach the fibreboard air diverter so more air goes through the editor ( oops, "Radiator"): probably not needed here!
Any other possibilties?
michael
ckeithjordan
My '57 built TS20447LO has the bent stays.
Dr_Mike
Isn’t that for one of the bumper braces on a wide mouth?
Aha!
you are quite right, and thank you. I dug out the front bumper and there it was: brand new with overriders and their stays attached.
the air deflector must get pinned under the stay.
i shall put it all away again for a while knowing that it will be there in one piece when i am ready.
the right side horn is perilously close to the radiator and
I shall keep a close eye, or ear, on it.
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
F TR2/3/3A TR3A tub assembly Triumph 44
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
T TR2/3/3A tr3a hood lift spring assembly Triumph 11
T TR2/3/3A Question on TR3A hood lift assembly Triumph 2
Tinkerman TR2/3/3A Water pump order of assembly '60 TR3A Triumph 1
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
L TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics Triumph 4
Tinkerman TR2/3/3A TR3A Windscreen sequence of assembly Triumph 4
Tinkerman TR2/3/3A Accelerator Assembly Installation TR3A Triumph 3
Tinkerman TR2/3/3A TR3A Accelerator Assembly Triumph 6
Tinkerman TR2/3/3A TR3A Accelerator Pedal Assembly Triumph 9
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
Tinkerman TR2/3/3A TR3A Order of Assembly Triumph 5
Tinkerman TR2/3/3A TR3A Handbrake Assembly Woes Triumph 6
apbos TR2/3/3A TR3a engine assembly Triumph 3
K TR2/3/3A TR3A Park Brake Compensator Bar Assembly Picture? Triumph 7
M TR6 Filter housing assembly? Triumph 7
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
N TR5/TR250 Starter Box Assembly Leak Triumph 14
D TR2/3/3A Windshield assembly question Triumph 6
K TR2/3/3A The horn and turn signal assembly. Triumph 3
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
tr6nitjulius For Sale "PRICE REDUCED" 4Sale: TR6 (L/R) taillight assembly Triumph Classifieds 0
Rob Glasgow Check Strap Assembly Austin Healey 5
bighealeysource Drum Brakes Assembly Austin Healey 6
D BT7 Choke Assembly Austin Healey 18
B TR4/4A Ammeter Assembly Triumph 2
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
SherpaPilot TR6 Choke Assembly Triumph 0
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
S TR2/3/3A tappet assembly Triumph 10
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
Csarneson Body panel assembly order? Austin Healey 6
T Articles by Hap Waldrop reg engine disassembly and assembly Spridgets 1
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
R TR2/3/3A Transmission Lever Assembly Triumph 9
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
steveg Points assembly order of washers Austin Healey 13
Lin Healey assembly line - engine installation Austin Healey 19
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
