Hi Guest!
I have swapped the two heavy wire leads, including the overdrive relay wire. The gauge now records a positive, steady reading on the plus side.Can you define “erratic”? I’ve got a similar setup, pos ground, with a shunt. On start up, ammeter reads high for 20-sec or so, while the battery is charging. Then for the first 10-min or so, I’ll see some spiking, irrespective of the load (like my OD). Then it goes away. Not concerned.
Thanks Steve. The engine has just been rebuilt with almost all new components. Professional friend did the rebuild, used lots of lube. This is the third TR engine he has built with me.Charley please pour oil on the lifters and cam with the valve cover and any other cam shaft voodoo you know. I want to keep my club very small.
steve
Bruce,I am getting ready to convert my voltage regulator to a "dummy" as Hamish shows above. So I assume that this conversion would be the same for my TR4A correct? There is a comment below that by Steve stating not to connect the "F" wire. I assume he means just tape it? I have searched for Randall Young's post on this and surprisingly cannot find it despite spending considerable time on it. Does anyone have that post or direct me as I recall he had covered it very well. However I can use what is posted above but what is the definitive answer on the F wire? Bruce
yahoo.com and I will send them to you. DickThe problem with posting emails in a forum is that "bots" that crawl the interent (like Google does) will see it as an email address and "harvest" it to use in their lists that they spam people with. However, if you look under the smilies icon in the editor you will see I have a "smilie" that is an image of the @ sign. This allows you to post an email address that a human can read, but those spam bots that crawl th net will not see it as an email. So, if you need to post an email, it is higjly recommended you use that "picture" like this: basilDick, you can go back and delete your address.
Charley
britiishcarforum.com << Any human can read that, but a bot will not see this an an email address - much safer if you need to post your email address.
