I have seen some posts on the installation of a shunt on the back of the amp gauge. What does that do, an where is it installed?Yes, I have neg ground and the Dummy Regulator installed. The engine starts right up and runs fine but, the amp meter fluctuates between 0 and -15.
Dick
I have the C40 Style neg ground alternator that looks just like the old generator. I bought it from British parts Northwest along with the NCB100XB Dummy Regulator. It has the diode setup inside. Both came with wiring diagrams for setup.A shunt is used to change the ammeter's range. It won't affect what you are seeing.
By a "dummy regulator" you mean just a box with no innards, right? If there still is some stuff in the box, it could cause what you are seeing. Looking at Hamish's photos, I would leave the field (F) terminal disconnected, not grounded (E terminal). That could cause what you are seeing.
What kind of alternator are you using? Does it have an "S" (sense) terminal? If so, that should be connected to some point in the electrical system.
Do you have another ammeter you can try? It's possible that the ammeter just coincidentally started sticking right now.
In the end, you might just have a bad connection somewhere.
Mine is showing -15amps, not +15 amps?Yes, you need to reverse the leads on the amp gauge and that should fix it. Generally what happens after you start the engine is the amp gauge will show +15 to 20 amps but only for a short time just until the battery regains the charge then drop back to +1 or 2 amps.
Graham
Charley,To correct the negative reading on the ampmeter you need to switch the leads on the back of the ampmeter. This has been stated in my previous message as well as from Graham. This requires that you access the back of the amp gauge and remove and switch the connections from one spade to the other. You are now running the direct current ( DC) in the opposite direction with the negative ground.
Charley
Yes those are the wires. Just switch the spade they are located on.Charley,
I'm looking at a digital pic i took of the back of the dash. I assume the two wires to swap are the heavy brown ones? Dick
Switching the wires will make it read in the right direction, but won't change its erratic nature, unless the problem is the ammeter needle sticking on the (-) side of the meter. But Charley raises a valid question: is it continuously erratic or just for a minute or so after starting? If the latter, it may well be normal.
Is the shunt wire run from the two large brown wire connectors? DickJust for the record and in case somebody else is interested. I looked up my notes on what Randall Young recommended for the shunt wire. It is 3.5" long using a 16 awg copper wire. I have set up my amp meter with a shunt but am still a few weeks away from starting the car for the first time.
The shunt is the curvy white wire in the photo.
Charley
