I never removed the arms from the hub. So if I put them on backwards they should be facing towards the back of the car. Is this correct thinking?I can not tell which way they are tilted, but wouldn't it be hard to install the TRE if the taper was inverted?
The tie rod end are what came with the car. Still good. Can I remove camber by placing shims behind the back plate and the hub? Or should I go with the bushings with the off center hole? Peters says they move but did not give any suggestions.Or perhaps the TRE is from a disc brake car? On my car theirs no taper just straight threw bore. This car definitely has to much camber.
I have standard springs on the way. Yes I did . I never removed them from the hub carrier. Negative camber is when the bottom of the tire is further out than the top. But the book says Positive. I think things would work better if I did negative. Will try that.Rod I would go back to standard springs and no lowering kit if one got installed and use that as a baseline. You reused the steering arms that came with the car correct? Rut I can 't remember if steering arms are handed. I don't think so. As long as there is a match between BE Rack and BE steering arms. Racks changed to Trimph Rack in '72.
Rod I still thing you've got camber settings leaning the wrong way. Should be 1/16" negative camber and 15 threads showing usually gets you there. Try that and see how it feels then. Did you replace shocks with a set of Peter C's?
Trunnions are now correct. I have never found the information on the String method. Can you send a link?Sim,
just to recap...your upper trunnions were installed backwards creating a lot of positive camber, has that been corrected? If so, center your steering wheel and with the car on the ground adjust your toe using the string method. Camber and caster are set and only the camber can be changed with offset bushings which you don't need to address yet. Using the string method set the toe in to 1/16" and you should be good to go. The tie rod ends should screw onto the tie rods and have an equal amount of threads showing, about 15 on each side. That is your starting point and from your previous pictures you have around 18 to 22 threads showing. Let us know how things go and post more pictures.
Rut
Ok took measurements and adjusted I think I am very close to no toe in and no toe out. did a short test run and it felt much better. I still think it is not tracking center line of car straight down the road. Still a little left.Steering arms look ok and the thread count, as close as I can tell, is more than 15 showing. Once the upper trunnions are installed correctly I don't really see an issue. The car needs to be on the ground to properly align the front end and most people use 1/16" toe in.
Rut
I did find the the back right wheel has a 1/8 inch toe out and the left back may br 1/4 inch toe out but I need to recheck that
I will put it back on the lift and checkIs the spidget track the same front to back? Some cars are not and I don't remember for sure. If the track is the same then a tow out on the rear wheel's is almost an impossibility! Further checking is required and I would set front at a little tow in. Much easier driving. I set tow with a couple of 1X4s 8 feet long. Just set them up against the front wheels and measure right in front of the wheels and then at the ends of the boards. I then flip them and do it again to account for any warp.
Kurt.
That's what I thought!
Explains the tow out and means that a little more tow in needs to be applied to the front with the string method.
Kurt.
