T-Series Adding a battery cut off switch.
vping
Bronze
I've been working on this '65 and have had lots of electrical problems. The latest is that something went haywire, the ignition light never went out and when I popped the hood to see what was up, the genny wires were smoking. One, bad generator and regulator later and I'd really like to add a switch to thie guys car.
I have one in my roadster and it is mounted through the vertical panel right in front of the battery box. It's the one with the large red key.
Anyway, this '65 is far too nice to do the same thing to so it got me thinking. I'd like to fill the hole where an OD switch is supposed to be but I doubt that switch can handle that much load. Can I add a relay at the battery then run smaller wires to the OD switch? If so, how do I determine what size relay to use?
Cheers
Vince
billspohn
I'd keep a switch to the battery area.
You might look into the battery ends that have two parts separated by a plastic bit - you need to screw down a large plastic knob to make or break the connection. Great for quickly disconnecting cars going into storage.
Moroso makes them, Amazon sells them.
fogliner
Hi Vping.
I drive a truck for a living and we have night switches on some of them that shut the batteries off for weekend parking etc.High amperage stuff and reasonably priced too.
I used 1 in my '74 and have it mounted behind the passenger seat on the front of the battery compartment.
I mounted it close to the battery and soldered and heat shrinked all my connections.
Check peterbilt,Kenworth,International parts departments.
All 12 volt stuff and mine works great. Just remember not to turn the battery switch off until after you shut the car off,sounds silly but it could happen and then you would fry the diodes in the alt/gen and have problems.
Probably the only drawback to having the switch there is the risk of inadvertent activation by falling grocieries etc.
Good luck with your wiring. Mark
vping
vping
Bronze
Thanks Bill but in the event of a short or fire, getting to that switch would take too much time to undo the carpet, battery cover.....
I have that type of switch in my '74 Mark and do like it. This '65 I've been working on is a restored car and it really would not look right which is why I was shooting for the OD hole.
Scott, Can that stinger be controlled by a little switch like the OD switch or is it not like that?
JTB
That battery cutoff switch behind the passenger seat saved a car fire for me twice before I replaced the main harness. Now it's extra security for theft, allows me to turn the battery off every time I park it. Not long ago I started car after 1 and 1/2 years parked...and the battery was still good and cranked right away. NO recharge needed. May not look original but I prefer the accessiblity from the drivers seat.
bob67bgt
Large red key can be painted black (or paint whatever switch you use black)and mount it near the inside corner of the rear bulkhead to further hide it. Basicly one set of points in the regulator stuck shut when you turned the key off. Bob
Billm
If you really want some theft deterrent just wire a low current horn across the cutoff switch, if anyone tries to hotwire it the horn will blow until the switch is turned on.
BillM
Scott_Hower
Vince-
Sure; no probs. The OD switch would be a perfect trigger for the relay coil. It only draws a few milliamps.
Keep in mind, it you accidentally shut it off when driving, you will lose power to everything and as pointed out, could fry the alternator.
If it were mine, I'd hide the switch controlling the relay coil.
vping
vping
Bronze
So far the car has no issues once I replaced the generator and regulator. It's still holds a charge and is charging. I'll have to revisit this with the owner the next time I see him.
DNK
It is a circuit breaker. Will trip if something shorts the electrical and is easy to isolate the battery. Just push the button.
DNK
I thought if you had a "B". An emergency pull was standard
PAUL161
Vince, Here's a couple switches which are on some farm equipment. They don't stick out very far and are keyed with a non standard key. Not like the Walmart brand. Most John Deere farm equipment dealers should be able to get one for you, or possibly have one in stock. When the key is out, you have the option of placing a cap over the key slot. PJ
<span style="font-weight: bold"><span style="font-size: 10pt">700 amp #APF12764-R $52.00</span></span>
<span style="font-weight: bold"><span style="font-size: 10pt">450-500 amp #APF5065-R $45.00</span></span>
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
steveg TR6 Adding a PCV valve Triumph 5
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
I adding a second fuel pump Austin Healey 16
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
Geo Hahn Adding Diode to OD Wiring Triumph 2
M Adding Picture FORUM Navigation Questions 2
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
M Adding Disc Brakes to a BN2 Austin Healey 7
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
T TR6 Adding lightness to a TR6 Triumph 26
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
K Adding a Radio BN7 Austin Healey 7
AltaKnight Adding JAM Triumph 22
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
Geo Hahn Adding a Headlamp Relay Triumph 19
N Adding an O2 sensor to exhaust? Triumph 25
P Adding pictures? Triumph 15
B Adding lap belts Spridgets 14
OregonTR4A Adding gear oil to the gearbox? Triumph 8
Tronch Adding Fuses Austin Healey 4
19_again adding pix to a post MG 6
vping Adding OD to my '67 MG 23
jjbunn Adding a vacuum gauge MG 18
drooartz Adding a bike Other Cars 40
tony barnhill Still "Adding Lightness" MG 39
S TR4/4A Adding overdrive to tr4 Triumph 7
