........ A Few More Questions
AngliaGT
Is there a tool to remove the fill/drain plugs on a MKIII Midget?
How do you remove the bump stops on the rear axle?
What size nut holds the air filter covers together? (can't remember-
where I put it).
- Doug
The rear bump stops just pop off. If they are real hard, you may need to cut them off.
+1 on the 1/2 inch ratchet extension -- works like a charm. I was able to pry out my front bump stops with a screwdriver. I had no intention of replacing them, so if I destroyed them in the process, it was no great loss.
Stock air cleaner bolts or the "competition" type of air cleaner?
I was afraid that you'd say that (grinding down an extension),
I even tried the local Snap -On guy - no luck
The bump stops don't do anything?
The air cleaner assemblies are stock - I just misplaced the nut.
- Doug
Yes the bump stops do something. To clarify though ... you are speaking about the rear axle bump stops. When I cut them off (I cut the bumpstops themselves), I replaced them with new ones.
On the aircleaner nut, I do not know the original size ... just use one that fits.
There are multi-tools that can remove various plugs. I'll find a link to one in a minute.
ummm... ok, on that tapered plug wrench. The only ones I could find were in Australia and the UK. So, buy a cheap extension and start grinding/filing.
