Hi Rick - glad the pix are helping.
My particular car was noted on the British Heritage sheet as having come from the factory with black "leather interior" when built in '59 and so I decided to take extra care to match the original as close as possible for this step. I researched this a fair bit. My conclusion was what that basically meant was the seats were leather, as well as the cap rail all around the cockpit, not anything else. (of course one can do what one wants, and there is always debate about stuff like this - I was only trying to get this part of my restoration done as original, according to my research.)
The dash board and the rest of the interior is vinyl. I really feel the interior trim is a critical part of the restoration, and I was not going to buy on price, but rather research it to get it as close to original as possible. After consulting with
Mark Macy , who is a national concurs judge (good enough for me) I decided to use
Jonathon Skinner in the UK, and bought all the interior components from them. Not to start a battle here, as I know there is a low cost eBay seller a lot of guys use, but Mark was
really against seat kits that use "foam" (see para 2) instead of the correct springs and the horsehair). I also was persuaded to have Mark trim out my seats for a grand total of $800 including blasting, repairing, and painting the original steel shells, trimming out the seats, and return freight. Glad I did - the results are spectacular (no creases or folds), and my total time involved was an hour or so taking the old seats to a "We-Pack-It" store. Anyway... the entire interior - the
correct wool carpets (also original to a s/n 31xxx car - later ones switched to nylon), and all interior pieces, arrived in 2 very large boxes after I wrote Skinner a check for $2000.00 which included shipping.
The stitching around the steering column pocket was pre-sewn into the dash piece by Skinner - it fit perfect - just lay it on the dash and glue it down. The cockpit trim pieces were supplied as pre-cut sheets of leather that had to be fitted and glued to the steel u-shaped pieces (the elbow-rest pieces on top of the door are especially tricky because the leather is heavier than the vinyl, making the chrome button that goes in the end a tight fit).
The door panels came pre-trimmed from Skinner and include the very light foam padding as well as the backer board. I guess your reference to them was
from this posting here. I've only test fitted them at this time, and still haven't finished mounting them yet - this will come after I get the front fenders and nose completed shortly. But yes, Skinner, as well as Lou Metalko (post #3 in the door panel posting) and Mark Macy all talk about the downside of having too thick of an under pad. I'm quite certain the Skinner pads are correct in this regard.
Other pieces like the wool carpet and the vinyl for the dash and rear inner wheel wells had to be fitted (I followed
Mark's great guide for that rear inner fenders and it turned out well).
So that's it. Again, no knock on the domestic suppliers. It's just the route I chose -(I guess I do kinda' believe in "old world craftsmanship"). I found Skinner to be very friendly and knowledgeable if not a bit long on lead time - I get the sense they "make to order" and patience is to be expected. Anyway, when I added it all up, in the end it didn't seem to be any extra cost. And as it turned out the components arrived long before I was ready for them.
Hope this helps, B
