MGB 1977 MGB will only run on full choke
Lavo
Hi everyone, hope someone can help with this. A few weeks ago my car broke down on me causing me to be rescued off the motorway. After being towed home, I found that my spark plugs were black with soot i.e. Car had been running rich. I cleaned out the carbs, checking float levels and checking needles and seats were working in both carbs by blowing down the fuel tubes and making sure the needles cut off the air flow. I checked timing, replaced the distributor, checked valve lash and today I replaced the coil. A compression test shows 154, 154, 159, 154. I have managed to get the car running but as soon as I start to reduce the choke from maximum, the car stumbles and dies and also a sooty residue is being blown out of the exhaust. I have set the jets 2 full turns down from the bridge but nothing I have tried has worked. Does anyone have any ideas where I can go from here please.
Thanks.
JPSmit
sounds very very rich!
1. what carb are you useing?
2. Do you have the air filter on (and if so, what happens if it is off?)
L
Lavo
Hi, I'm running HIF4s and the air filters are off whilst I'm working on it. I have put my hands over the intakes and the engine dies off.
Gliderman8
I’m not familiar with HIF4 carbs, but I assume there’s a dashpot….
Have you checked to make there’s oil in there?
Mickey Richaud
Sounds like it's time to start over...
2 turns down from level with the bridge for the jets is a starting point; you may need to raise them a flat or two. And I'd try lighter weight, single viscosity oil in colder weather. Maybe something like sewing machine oil.
Have a read here: https://www.mgexp.com/phile/1/492119/SU_idiot_guide.PDF
And please keep us posted.
Mickey
L
Lavo
Cheers for that Mickey, I've printed the idiots guide off so I'll give that a go tomorrow with a lighter weight oil.
Dave.
Mickey Richaud
You're most welcome! Hope it helps you in your quest.
JPSmit
While you are at it, check your springs and cables. When it left you on the road the plugs were sooted (too rich) and when you got it reassembled it would only run on full choke (too rich) but when you let off the choke - at which point it should run better - even at half choke (less rich) - it dies, making me wonder if there is something mechanical between the cockpit and the carb that is binding/ kinking/ not fully opening or closing - could it be something as inane as the idle set too low?
Platinum
HIF4's are a different animal but the principles are the same. Jet levels and balancing in particular.
And Mick hit on another possible with throttle return spring strength.
Mr. Adler mentions ColourTune and air flow devices, the ColourTune tool is a good investment, I've two so as to see both carbs at the same time. As for the AFM, the one illustrated in the PDF is now "counterfeited" and not near as accurate or reliable as the original ones.
This type has been more consistent recently, prices are all over the map tho:
Bob Claffie
Only running with full choke and stalling out when it is eased off suggests a massive air leak somewhere in the intake system
L
Lavo
Thanks for that Bob, I have looked for a acuim leak bit can't find one. All pipes and connections have been sprayed with carb cleaner with no change whatsoever er in engine note. I'm at a loss.
JPSmit
Lavo, what was happening when the car broke down initially? had you repaired/replaced anything recently?
Cars don't typically jump out of tune.
maybe we need to go further back.
L
Lavo
hi John, I havent replaced anything recently, ie in the past 12 months, the car was going really well up until this happened. Right before the car finally stopped, there was a loss of engine power, pressing the accelerator had no real effect, the engine began misfiring and I had to coast off the motorway.
Platinum
That last description sounds like classic fuel pump failure!
L
Lavo
I have considered that but it does seem to be working ok. I've removed the fuel line from the carb and pumped fuel into a jar and there does seem to be a good supply.
JPSmit
do you have a bright spark?
L
Lavo
I put a spark tester on each plug in turn yesterday and spark seemed good on each. I'm going to start again today. I'll check everything that's been pointed out to me and get back to the forum. Thanks to everyone who's commented.
L
Lavo
Today, I went back to the start,static timing to 10btdc valve lash all checked, checked points And plugs all ok. Turned jets 2 full turns rich from the bridge. Car started really easily on full choke. Broke out the carb cleaner to check for vacuum leaks. Still could find none. Once the engine was warm pressed choke into halfway, the revs went up momentarily before the engine stumbled and died. Still sooty exhaust. I'm now thinking a full carb rebuild but I don't really know if this will cure it.
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Celtic 77 MGB 1977 MGB Brake issues MG 8
L MGB Rebuilding a 1977 MGB MG 1
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
Boggsy64 MGB Driving 1977 MGB 2000+ miles any concerns I should look in to?? MG 13
6 MGB 1977 MGB Exhaust Leak MG 0
QuickSilver MGB What size is the steering wheel on a 1977 MGB? MG 9
A MGB MGB 1977 oil pressure problem MG 31
A MGB 1977 MGB oil pressure problem MG 0
C MGB Console tunnel - 1977 - 1980 MGB MG 5
tony barnhill MGB The 1977 MGB "Survivor" MG 22
C MGB 1977 MGB Electrical Problems - fuse box MG 4
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
kyreb1862 MGB 1977 MGB Intake MG 7
kyreb1862 MGB 1977 MGB Master Cylinder MG 0
kyreb1862 MGB 1977 MGB Brake Master Cylinder Identification MG 7
A MGB What is this in a 1977 MGB? MG 14
C T-Series 1977 MGB ignition switch MG 4
kyreb1862 MGB 1977 MGB MG 9
A MGB 1977 MGB Antenna Installation??? MG 4
J MGB WTB: 1977 MGB intake/exhaust manifold MG 7
A MGB Buying 1977 MGB Advice Needed MG 3
1 MGB My new 1977 MGB? cant turn distributor MG 3
1 MGB color of carpet for 1977 MGB MG 4
Celtic 77 MGB 1977 seat webbing replacement. MG 1
M 1977 MG Midget 1500 Problem Spridgets 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
B 1977 Midget Bra Spridgets 9
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
kennypinkerton MGB 1977 VDO clock... can it be opened? MG 7
M MGB Tail lights do not work- 1977 MG 8
DrEntropy MGB 1977 B with some issues MG 3
J Spitfire 1977 Spitfire hard top Triumph 2
K 1977 924 Fuel Injection Other Cars 6
K 1977 Porsche 924 Other Cars 0
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
T MGB-GT 1977 MG BGT electrical MG 6
77_MG_Midget air pump on a 1977 1500 midget Spridgets 2
J 1977 MG HELP!!! Fluid issue MG 7
F what to do when you remove the bumper[1977] MG 4
Basil Panther/Jaguar 1977 Jaguar 2
A Wanted 1970 MGB - Emissions Parts MG Classifieds 2
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
