He's running SU HIF4s - no diaphragms.Do your carbs have diaphragms?
If you do, you might check for tears in them.
Beat me to it...He's running SU HIF4s - no diaphragms.
Thanks guys. As you can see I have no knowledge of the HIF4 carb. It was just a WAG.He's running SU HIF4s - no diaphragms.
it is worth noting that the last full moon was March 18 which I suspect had something to do with it.Thanks for the reply Tiger37, I was on the verge of a rebuild kit but a couple of weeks ago I decided to give it one last try. I took the carbs apart, gave them a good clean again, reset float levels but this time I fitted a fuel regulator. I don't know if it was the reclean and reset or the fuel regulator but its running much better now, idling is good around 900 so I'm really happy now.![]()
) - It is worth noting that if you take apart and reassemble an SU enough times you will end up with two SUs, so, you are likeley also on your way to an excellent spares collection - now get out there and drive!!!
