1950 Prefect Headliner
algot1901
I am in need of information, how many bows does thePrefect use for the headliner I have found a good price but I have no bows the spares dealer tells me 5 or 6.
Bayless
I'll check mine tomorrow. Meanwhile, where did you find it at any price? Small Ford Spares used to offer one but I see it is not currently available.
waltesefalcon
Shouldn't you just be using a towel if it's a Ford Prefect?
algot1901
algot1901
I am trying to find brake lining 9" x 1 1/4 any help would be welcome, is there any other rim that will fit this wide five bolt pattern I see there are some nice rims for the VW although I am more of a salvage yard guy. I have a couple of yards that are still back woods cash or check in my area, my main gripe is the cost for the tires.
Got my crank back from the turner and ordered the rest of the parts from small spares and the exchange rate is out of site well got to go and peel the gasket out of the top and it is a bitch. One other thing I had to replace 3 door glass $400 and change think I am going to put special insurance on just the glass.(y)
Stay Healthy
JPSmit
I was referencing Douglas Adams' seminal work The Hitchhiker's Guide to the Galaxy.
well I thought you were one froody dude!
Algot 1901 - Ford Prefect is a main character in the aforementioned book. Here is what wikipedia has to say:
Although Ford had taken great care to blend into Earth society, he had "skimped a bit on his preparatory research," and thought that the name "Ford Prefect" would be "nicely inconspicuous." The Ford Prefect was a popular British car manufactured from 1938 to 1961, and Adams later clarified in an interview that Ford "had simply mistaken the dominant life form" of Earth.
further, about towels
“A towel, [The Hitchhiker's Guide to the Galaxy] says, is about the most massively useful thing an interstellar hitchhiker can have. Partly it has great practical value. You can wrap it around you for warmth as you bound across the cold moons of Jaglan Beta; you can lie on it on the brilliant marble-sanded beaches of Santraginus V, inhaling the heady sea vapors; you can sleep under it beneath the stars which shine so redly on the desert world of Kakrafoon; use it to sail a miniraft down the slow heavy River Moth; wet it for use in hand-to-hand-combat; wrap it round your head to ward off noxious fumes or avoid the gaze of the Ravenous Bugblatter Beast of Traal (such a mind-boggingly stupid animal, it assumes that if you can't see it, it can't see you); you can wave your towel in emergencies as a distress signal, and of course dry yourself off with it if it still seems to be clean enough.”​
:cheers:
Bayless
I got all the glass for mine a few years ago and it is waiting for me to paint the car. Was $700+ including the window channels and felt scrapers. So yours is probably in the ball park. I hope you got tempered glass for the doors. The cost is almost the same as safety glass and not nearly as likely to break easily just by closing a door.
You can also check the headliner bows. there is one at each wood top bow and it is a short wire from where it screws to the side and stops at the wood where the headliner is tacked to the wood bow. There is at least one full wire bow behind the fabric top opening and again there should be obvious screw holes where it attaches to the body. I'll still check tomorrow on mine.
algot1901
algot1901
:cheers:
Near as I can tell Froody is a compliment, it is the first time I have heard this word and had to check the word bible.
Raining here to day temp is 63F
algot1901
algot1901
Would you mind sending me a photo of your headliner?
Thanks
Bayless
Can't do that. I haven't built it yet. I think I can get a photo of the bows though. We had a minor crisis at the shop today and I didn't get time to look in the Prefect but will try again over the weekend.
Bayless
Well I did go back to the shop and got these photos. One shows the wood top bows with the wire stubs below them. You should see where the wires attach on your car. Another is a detail of the wire stub attachment. Finally I have one of the three full wire bows at the back plus the stubs that end at the rear window. That makes a total of 8 bows, counting the stubs at the back window. Below those last stubs is a nailing strip where the headliner finishes. There is a nailing strip above the doors and the front has a hard panel that covers the attachment, also headliner material.
JPSmit
It is a compliment indeed. Hitchhikers guide is a bonkers trilogy (with 6 books) that was a radio program in the UK. It is mostly listening humour (radio) and takes things to their logical absurd extreme. a movie was made which is one of the worst movies I have ever seen in part because it relies on sight gags. Douglas Adamas the author sadly died at 49 years of age of an undiagnosed heart condition.
At any rate back to real Prefects.
algot1901
algot1901
I wonder why they did not run the bows full length at the hole or whatever you call it in fact I do not understand why they made the soft top. I thank you as it really helps thank you
JimG
Bayless
Remember, your car is just a facelift version of my '48 which was actually introduced in '39. That's how a lot of cars were made in the '30s. It was probably more difficult and expensive to form a fully steel top. Our shop is just about finished restoring a Model A and its top is quite similar although longer so there are no wire bows. Also, they omitted the short wires along the sides and just dropped straight from the wood top bow to the side. I understand the Australian version, which was introduced later, has a full steel top. Don't know if it is one piece though.
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 1950 Prefect starter Other British Cars 1
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
algot1901 1950 Prefect Ign Switch Other British Cars 1
algot1901 1950 Prefect Speedo Cable Other British Cars 8
algot1901 1950 Prefect Starter Other British Cars 10
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
A Body Paint Codes for 1950 Prefect E493A Other British Cars 1
A Rubber parts for 1950 Prefect E493A Other British Cars 6
A 1950 Ford Prefect Windows Other British Cars 4
A 1950 Prefect Vacuum Tank Other British Cars 22
A 1950 Ford Prefect Floor Covering Other British Cars 2
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
T For Sale Parting out a 1950 Austin A-90 Atlantic drophead Other British Classifieds 5
J Wanted 1950 Austin sheerline A125 need brakes Other British Classifieds 0
J 1950 Austin a 125 Shoreline need parts FORUM Navigation Questions 2
D 1950 Jaguar Mark V Sunroof Question Jaguar 0
K 1950 Standard Vanguard Other British Cars 2
AUSMHLY 1950 Healey Siverstone Austin Healey 8
B 1950 Rover 75 P4 Cyclops value? Rover / Land Rover 9
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
G Brake fluid recomendations - 1950's JAG XK140 Jaguar 19
Z Austin A70 Hampshire [1950] as a donor car Austin Healey 1
kennypinkerton British Specials... from the 1950's Other British Cars 38
kennypinkerton More specials... 1950's Racing 1
Tullamore 1950 Simca Pinninfarina Sport Huit Other Cars 1
T looking for any info on a 1950 austin A40?? Other British Cars 5
Sherlock TR2/3/3A 1950's Triumph TR2 Francorchamps coupe Triumph 3
KLUTZ 1950 FORD ANGLIA. in Old Car Trader. Other British Cars 13
Kira Smiths Clocks Pre 1950 Other British Cars 6
B 1950 Healey Silverstone D-Type on E-bay Austin Healey 1
bighly 1950 MG YA [For Sale] MG 2
Bayless The Prefect Grille Other British Cars 0
Bayless More Prefect Progress Other British Cars 2
algot1901 50 Prefect wood roof support / bow Other British Cars 8
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 Brakes for Anglia / Prefect Other British Cars 2
Bayless My Prefect update Other British Cars 5
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
algot1901 Carburator 50 Prefect 1172cc engine 10hp Other British Cars 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Bayless Even more progress - the Prefect Other British Cars 5
L !953 Ford 4 door Prefect Other British Cars 3
KLUTZ Wow.. A Perfect Prefect ....... Other British Cars 2
A 1949 - 1952 Ford Prefect Other British Cars 9
