Over the last couple of years I added a Toyota 5-speed gearbox, and a 3.54:I ring and pinion set to my differential. On top of that I run non-standard tires. As a result, my speedometer doesn't register anything near to an accurate speed. I have been meaning to take the simple measurement of counting the number of revolutions my speedometer cable turns over a set distance that is some fraction of a mile, and then send the speedometer to one of the usual suspects to have it re-geared to correct for this. However, I found it easier and probably about the same cost to install a GPS-driven speedometer which I have just completed.
I have no bias for this company. I chose a Speedhut unit and so far I am very pleased. I shopped around looking for something that looked as much like the Smiths gage as I could find. I did not want one of the various units out there that drive off the speedometer cable which goes into a converter box which you can calibrate to your needs. Finding one that was self contained, save for the small antenna, was not going well until I found Speedhut. Lots of cheap units out there that might look fine in a ski boat but not so much in the Healey. I selected the features that most resembled the origional.
I did not select built-in turn signal indicators or a high beams LED, but they are offered. Simple 3 wire install, ignition power, lighting circuit power and ground. The antenna works fine situated on the dash behind the steering wheel. The small digital display offers lots of features I probably won't ever use. Their customer service seems very good and it is built in the US. It took less than 2 weeks to get my bespoke ( I've always wanted to use that word) speedometer. Aside from the bezel being a satin finish rather than chrome and being a little fatter, I think it looks acceptable.
