Alfred E. Neuman
@CJD, I haven't noticed any cracks at the head stud threads. I'll double check when I go to the shop this afternoon to clean the bock.
That is a broken oil pan bolt. There's not enooug sticking out to get a good grip on it with vicegrips, but should be enough to weld a nut to.
Otherwise I'll drill it and get it out. Worse case scenario is a TimeSert. I've got 5/16-18 on hand if needed.
Hi Guest!
